i need pictures of pass word jdm 3 point strut tower bar
hi there! just wondering if there's anybody that has a picture that i can look at of password jdm 3 point strut tower bar installed in an EF. just want to see where you guys relocated the thing (i don't know what that is) that's mounted on the fire wall.
i am about to buy the strut bar but i know that something has to be relocated. pls help a noob here! thanks in advance!
thanks for the inputs guys! i'll just zip tie it onto the strut bar. or i can extend the wires and the vacuum hose and bolt it to the extra mounting hole to the right near the brake master cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsi888 »</TD></TR><TR><TD CLASS="quote">thanks for the inputs guys! i'll just zip tie it onto the strut bar. or i can extend the wires and the vacuum hose and bolt it to the extra mounting hole to the right near the brake master cylinder.</TD></TR></TABLE> or if you want to get another OBD1/OBD2 Throttle body it has the map sensor located directly on it. Then you can completely remove your old map and just zip tie your Purge solenoid valve. Or if nothing else just wrap it on the A/C lines...that is what I did with just my PSV though. GL
