Fuel system too rich or lean .... what to do?
Old Sep 11, 2007 | 01:14 PM
dubbin's Avatar
Default Fuel system too rich or lean .... what to do?
I have a 96 cx as a 'beater' to get me around the city and park werever. I wasent driving it much during the summer and i am now needing it. It was taking tons of gas for the past year and finally decided to fix it. It was a cracked manifold i changed that and the gas consumption seems fine now (450km a tank) but the check engine came back a couple days ago with the ' fuel system too rich or lean'....what is this caused by? The car has new plugs and i actually put a bottle of injector cleaner in the tank of gas that i am running now....???
I was thinking the primary o2 sensor, but i figure if its seeing lean or rich its because its working properly...no???
any clues guys?
thanks
Mark
Old Sep 11, 2007 | 01:29 PM
drtysohc's Avatar
try replacing the o2 sensor(s) and see what happens.
Old Sep 11, 2007 | 01:51 PM
philosofy1's Avatar
Default Re: Fuel system too rich or lean .... what to do? (dubbin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubbin &raquo;</TD></TR><TR><TD CLASS="quote">I have a 96 cx as a 'beater' to get me around the city and park werever. I wasent driving it much during the summer and i am now needing it. It was taking tons of gas for the past year and finally decided to fix it. It was a cracked manifold i changed that and the gas consumption seems fine now (450km a tank) but the check engine came back a couple days ago with the ' fuel system too rich or lean'....what is this caused by? The car has new plugs and i actually put a bottle of injector cleaner in the tank of gas that i am running now....???
any clues guys?
thanks
Mark</TD></TR></TABLE>
actually if the o2 sensor goes out, then the motor will run lean or rich. it is unable to send the proper messages to the ecu. i suggest replacing both of them, that way you won't come across this problem with the seconadry o2 sensor.
Old Sep 11, 2007 | 03:12 PM
dubbin's Avatar
both sensors?
isnt that a bit excessive ?
I'm thinking maybe just the precat since the post cat has absolutely nothing to do with A/f's ...its only there to verify if the catalic converter is proper?!
thanks guys
MArk
Old Sep 11, 2007 | 05:35 PM
dubbin's Avatar
help me out guys!
Old Sep 11, 2007 | 06:00 PM
drtysohc's Avatar
you are correct about the cat, but i wouldn't rule out that it could be part of your problem. replace the first one, see if it makes a difference, then replace the second one if need be.
Old Sep 12, 2007 | 03:18 AM
dubbin's Avatar
Default Re: (drtysohc)
I'll do that i guess....could any thing else be the culprit?
any one else have his problem?
thanks again
MArk
Old Sep 12, 2007 | 03:28 AM
97Ej6mike's Avatar
Default Re: (dubbin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubbin &raquo;</TD></TR><TR><TD CLASS="quote">I'll do that i guess....could any thing else be the culprit?
thanks again
MArk</TD></TR></TABLE>
If your MAP sensor is broken, (rarely the case), it wouldnt send the correct signal to the ECU, which in turn would cause it to put in too much fuel. But you would know about this beforehand, 1.) from a CEL, 2.) really poor gas mileage.
Old Sep 12, 2007 | 06:22 PM
dubbin's Avatar
Default Re: (97Ej6mike)
any pictures on this site that would show were the MAP happens to be on this car?
Old Sep 12, 2007 | 10:50 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dubbin &raquo;</TD></TR><TR><TD CLASS="quote">any pictures on this site that would show were the MAP happens to be on this car?</TD></TR></TABLE>
the map sensor should be located on top of the throttle body.
Old Sep 13, 2007 | 03:50 PM
97Ej6mike's Avatar
Default Re: (philosofy1)
11 37830-P0G-S00 SENSOR SET, MAP 1 1997 CIVIC
It will be part #11, the 3-wire sensor, right on top of the throttle body.
88 EF Hatch
May 28, 2009 05:01 PM
junkyarddogg81
Oct 14, 2007 04:24 PM
Mrs . M i c h a e l
Mar 4, 2006 08:59 AM
Wannabe JDM
Feb 9, 2006 04:19 PM
