Motor Need Help Fast!!
Old Sep 11, 2007 | 01:09 PM
NcJdmEk's Avatar
Default Motor Need Help Fast!!
I am puting a d16z6 motor in my 98 civic cause the motor went out... my car is a 5spd. i have the other car at my hse. its a 94 civic ex. all i need to know is am i going to have to get the ecu programd for me to run a 5spd? the other car have an auto in it. all i m useing on the 94 is the motor, wireing, ecu,axles, all i need to know is about is the 5spd change over?
Thinks Guys,
Brandon
Old Sep 11, 2007 | 01:20 PM
95sloweg's Avatar
Default Re: Motor Need Help Fast!! (NcJdmEk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NcJdmEk &raquo;</TD></TR><TR><TD CLASS="quote">I am puting a d16z6 motor in my 98 civic cause the motor went out... my car is a 5spd. i have the other car at my hse. its a 94 civic ex. all i need to know is am i going to have to get the ecu programd for me to run a 5spd? the other car have an auto in it. all i m useing on the 94 is the motor, wireing, ecu,axles, all i need to know is about is the 5spd change over?
Thinks Guys,
Brandon</TD></TR></TABLE>
Is the d16 a 5spd, cause if it is then all you need is the ecu from the d16. i am so lost on what you said.
Old Sep 11, 2007 | 01:27 PM
drtysohc's Avatar
so the car that it is going in was originally a 5spd? If so, you just use the same ecu that was in the car, or you can go ahead and use the one from the z6 as long as it is a manual too.
Old Sep 11, 2007 | 01:30 PM
philosofy1's Avatar
Default Re: Motor Need Help Fast!! (95sloweg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sloweg &raquo;</TD></TR><TR><TD CLASS="quote">
Is the d16 a 5spd, cause if it is then all you need is the ecu from the d16. i am so lost on what you said.</TD></TR></TABLE>
so why bother posting, oh wait maybe to help your score!
Thinks Guys,
as long as you are just using the motor you are fine. keep the current ecu from the 98, the auto ecu is not needed here. the only thing i would be concerned about is the motor is from a 94 (obd1) and the ecu is a 98(obd2). i'm not sure exactly what is compatible between the two. but if you can swap everything from the old motor to the new motor and they are in working order then you shouldn't have any problems.
Old Sep 11, 2007 | 01:32 PM
gsxr1k05's Avatar
you can run a manual trans with an auto ecu. i did with my 90 crx auto2man swap. i would also assume you can run an auto trans with a manual ecu. but someone let me know on that cause i am doing a man2auto swap in a few for a friend who cant drive stick.
Old Sep 11, 2007 | 01:47 PM
philosofy1's Avatar
Default Re: (gsxr1k05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">you can run a manual trans with an auto ecu. i did with my 90 crx auto2man swap. i would also assume you can run an auto trans with a manual ecu. but someone let me know on that cause i am doing a man2auto swap in a few for a friend who cant drive stick.</TD></TR></TABLE>
yes you can run a manual tranny on a auto ecu, but i doubt you can do it the other way around.
but the op doesn't have to worry about that since all he is doing is swapping the actual motor not the tranny.
Old Sep 12, 2007 | 10:30 AM
NcJdmEk's Avatar
Default Re: (philosofy1)
yea all i am doing is puting a z6 motor in a 98 civic i am using my 98 5spd tranny. and from tha 94 just the motor like i said and the wiring harness and may be a chiped ecu that is obd1
JDM215
Apr 13, 2009 02:52 PM
94dxcivicve
Oct 11, 2006 10:41 AM
slow_455_civic
Aug 13, 2006 10:14 AM
Lees_89_CRX_HF
Apr 5, 2004 06:10 PM
