blox cams
whats the differnence in the BLOX tuner series type b and the tuner series stage 2?? and would they be comparible to a s2p2 cam???
im running a
b18c5 with jdm p73 00 oversized .25 pistons compression is like 11.5:1
and a super tech valve train
im running a
Tuner series - S2S1/S2S2/S2S3 = Blox A/B/HSL. Blox C is an exact duplicate of the Jun3, primaries and all.
"Comp" series = Pro1/2 and I believe they make a 3.
For your motor, Pro1, S2S2/Blox B/C or M22x would all be good cams for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Tuner series - S2S1/S2S2/S2S3 = Blox A/B/HSL. Blox C is an exact duplicate of the Jun3, primaries and all.
For your motor, Pro1, S2S2/Blox B/C or M22x would all be good cams for you.</TD></TR></TABLE>
uhh.. Blox and Skunk are not the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToeJam »</TD></TR><TR><TD CLASS="quote">
uhh.. Blox and Skunk are not the same. </TD></TR></TABLE>
uhh yea they are, everything from both companys is made in the same exact warehouse
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner »</TD></TR><TR><TD CLASS="quote">
uhh yea they are, everything from both companys is made in the same exact warehouse</TD></TR></TABLE>
Because they were made in the same warehouse doesn't mean they were made to the same specs.
If I were to order the same type of cake (cam) from the same caterer(company) as my competitors, but I put different spices (cam specs) in mine and they put lemon in theirs, then do we have the same taste? Are we still then the same cake? I think not.
the duration and lift on the Skunk stage 2 and Blox tuner B's are bery much different. Meaning they both will have different effects on where the powerband begins as well as how long it carries.
so for my setup im getting ready to purchase some blox cams and dont know between tuner series or comp series... comp series is similar to s2 pro series right??? what is the most similar to s2pro1's?
tbones
Mar 20, 2007 04:00 PM
B18cHatch06
Aug 17, 2005 08:43 AM
