What gauges of wire are on the stock '99 Civic Si POSITIVE battery terminal?
Old Sep 11, 2007 | 12:34 PM
Sprockets's Avatar
Default What gauges of wire are on the stock '99 Civic Si POSITIVE battery terminal?
I searched and searched, but couldn't find the answer. I'm not looking to relocate the battery, but I just want to replace the positive terminal and use the existing wires. The terminal I want to buy has 8 gauge screw outputs, and I was curious if this would be enough. Thanks for the help!
Old Sep 11, 2007 | 12:54 PM
B18C_EJ8's Avatar
Factory battery wires are closer to 4 ga.
An 8 ga terminal will be too small.
Old Sep 11, 2007 | 06:32 PM
Sprockets's Avatar
Default Re: (B18C_EJ8)
They look smaller than 4 gauge, though. Is it 6 gauge?
Old Sep 11, 2007 | 06:45 PM
fcm's Avatar
fcm
Old Fart
Default Re: (Sprockets)
Yea probably 6ga.
Where are you going to relocate the batt. to, and why.
You do know Honda put the batt. there because it is the best place for it, right?
If you insist on moving it, keep in mind the longer the cable is, the bigger it needs to be to be able to deliver the same amount of current to any of the loads, starter motor being at the top of that list. 94
Old Sep 11, 2007 | 07:47 PM
Sprockets's Avatar
Default Re: (fcm)
LOL, re-read what I wrote. I don't want to move the battery.
Old Sep 12, 2007 | 08:18 AM
fcm's Avatar
fcm
Old Fart
Oops, had you confused with someone else.
Then no, the 8ga terminal will not work, is this just for looks? 94
Old Sep 12, 2007 | 10:47 AM
Sprockets's Avatar
Default Re: (fcm)
That's OK. It's sort of for looks. I'm upgrading my grounds. It's not one of those ricer kits. I bought a plain silver negative terminal with wire and everything to do it myself, and thought it will look stupid next to the stock positive terminal. The only positive terminals I can find on Ebay are either huge and blocky with a shiny finish, or this one:
http://cgi.ebay.com/SOUND-QUES...wItem
It has 2 8 gauge holes, but I really don't want to use ring terminals. I'll keep looking. Thanks for letting me know what gauge wire it is.
JuneBugDrfter
Feb 26, 2013 11:49 AM
87-EF rEx
Oct 9, 2005 11:52 AM
byathread
19
Sep 26, 2003 09:52 AM
KooK
Jul 21, 2003 02:49 PM
fakemike
Aug 2, 2002 02:38 PM
