what size sway?
What size is the front sway bar on a 97 SE (Glorified LX)
Want to get new bushings for it. Thanks
If I remember it was 22mm someone correct me on this.
Measure it. Get under the car and use an adjustable crescent wrench. Snug it down until it just touches, then measure the gap with a mm ruler. Check it in 2-3 different areas, it should measure the same. I have done this before-it works.
Some years (per model) may run different swaybars (say 20 and 22mm), but if you measure carefully you will know which one you have. Get bad data, or guess wrong, and you will end up with an opened bushing kit the seller probably won't replace. Wrenchy
