Accord trannys...
Old Jun 16, 2002 | 03:00 PM
Wo-Nelly's Avatar
Default Accord trannys...
Could someone make a list offf the different trannys the accord uses from 90-01? Where do the gears end at mph wise? For instance:
1st-xxmph 2nd-xxmph and so on. Thanks
Old Jun 16, 2002 | 03:17 PM
Martaigne's Avatar
Default Re: Accord trannys... (GottaLude)
5th gen EX Coupe:
1st - 35 mph (give or take a few)
2nd - 60 mph
3rd - 90 mph
4th - 110 mph
5th - 140 mph+
Old Jun 16, 2002 | 04:18 PM
Nick H's Avatar
New User
Default Re: Accord trannys... (martaigne)
so...if someone had a large enough turbo...where would 5th gear end?...i mean what is the maximum speed you can go in the accord...? my guess would be 170 maybe?
Old Jun 16, 2002 | 04:20 PM
Gennady's Avatar
New User
Default Re: Accord trannys... (nickh2k1)
It would end when you hit rev limiter or fuel cut off.
Old Jun 16, 2002 | 04:54 PM
Nick H's Avatar
New User
Default Re: Accord trannys... (Wont be beat)
yes i know that...but what speed would that be?
Old Jun 16, 2002 | 05:08 PM
YeuEmMaiMai's Avatar
many people say 112mph is the top speed if you have a hondata there is no top speed limiter in the software so it would be where the engine could no longer overcome the drag on the car
my guess is that since 4th on the auto is about 3K for 70mph and if you could get up to 6K that would be 140ish or so
I believe that top speed would be in 4th gear on the manual since it would take a LOT of power to reach terminal velocity in 5th more than 300+hp???? (a guess)
[Modified by YeuEmMaiMai, 2:10 AM 6/17/2002]
Old Jun 16, 2002 | 05:52 PM
Wo-Nelly's Avatar
Default Re: Accord trannys... (YeuEmMaiMai)
Whats year is the 5th gen? What other tranny's are there?
Old Jun 16, 2002 | 06:41 PM
Brandon's Avatar
Life is Suffering
I calculated it at 162mph with the stock redline.
Old Jun 16, 2002 | 06:52 PM
Martaigne's Avatar
94-97, though I can't speak for the 97 because it's OBDII and that may change some specs.
Old Jun 16, 2002 | 06:54 PM
Martaigne's Avatar
Uh, no, I've hit 125+ in my Accord with only intake and exhaust. It was still accelerating too, albeit slowly.
Old Jun 16, 2002 | 07:14 PM
Wo-Nelly's Avatar
is the lx tranny anydifferent or do all accords for those years share the same tranny?
Old Jun 16, 2002 | 08:35 PM
Nick H's Avatar
New User
same tranny...
Old Jun 17, 2002 | 04:28 AM
SOHCArchangel's Avatar
lemme guess noone (other than dave or myself) has a spreadsheet done of the different gearing, am i right?
Old Jun 17, 2002 | 06:30 AM
Stew Pidasso's Avatar
I've hit 135 MPH in mine
Me too!
Old Jun 17, 2002 | 07:48 AM
Martaigne's Avatar
Default Re: Accord trannys... (SOHCArchangel)
Share, biatch!
Old Jun 17, 2002 | 08:11 AM
uhh 125 is not terminal velocity in an accord........... someone asked what the top speed in top gear was...... a sho has waayyy more hp and it cannot reach top speed in 5th it actually reaches top speed in 4th gear (147 for a '89 all newer ones are governed at 139mph)
same for the corvette top speed comes in on 5th not 6th
Old Jun 17, 2002 | 08:27 AM
Martaigne's Avatar
No, it's not. It sounded like you meant that the fastest an Accord can go was in 4th gear, was just saying that's false. Sorry for the misunderstanding.
Old Jun 17, 2002 | 08:41 AM
p0pe's Avatar
I do, but I'm at work.
Old Jun 17, 2002 | 09:02 AM
H23 Power's Avatar
Default Re: Accord trannys... (p0pe)
153 is the theretical(sp?) top speed of a 5th gen ex if you had enough power
Old Jun 17, 2002 | 09:06 AM
John's Avatar
New User
Default Re: Accord trannys... (01GSR)
The key word there is if.
H23 Power's Avatar
6th gen 98-01 accord 4 cylinder
34
63
94
125
164
Old Jun 17, 2002 | 01:40 PM
TypeSH's Avatar
ive done the spreadsheet for a 5th gen EX/Coupe, H23A/H22A
h22a
RPM 1st 2nd 3rd 4th 5th
200 1.02 1.73 2.48 3.15 3.88
400 2.04 3.46 4.96 6.30 7.76
600 3.06 5.19 7.45 9.45 11.64
800 4.08 6.92 9.93 12.61 15.52
1000 5.10 8.65 12.41 15.76 19.40
1200 6.12 10.39 14.89 18.91 23.28
1400 7.14 12.12 17.37 22.06 27.16
1600 8.17 13.85 19.85 25.21 31.04
1800 9.19 15.58 22.34 28.36 34.92
2000 10.21 17.31 24.82 31.52 38.80
2200 11.23 19.04 27.30 34.67 42.68
2400 12.25 20.77 29.78 37.82 46.56
2600 13.27 22.50 32.26 40.97 50.43
2800 14.29 24.23 34.75 44.12 54.31
3000 15.31 25.96 37.23 47.27 58.19
3200 16.33 27.69 39.71 50.42 62.07
3400 17.35 29.43 42.19 53.58 65.95
3600 18.37 31.16 44.67 56.73 69.83
3800 19.39 32.89 47.15 59.88 73.71
4000 20.41 34.62 49.64 63.03 77.59
4200 21.43 36.35 52.12 66.18 81.47
4400 22.45 38.08 54.60 69.33 85.35
4600 23.47 39.81 57.08 72.48 89.23
4800 24.50 41.54 59.56 75.64 93.11
5000 25.52 43.27 62.05 78.79 96.99
5200 26.54 45.00 64.53 81.94 100.87
5400 27.56 46.73 67.01 85.09 104.75
5600 28.58 48.47 69.49 88.24 108.63
5800 29.60 50.20 71.97 91.39 112.51
6000 30.62 51.93 74.45 94.55 116.39
6200 31.64 53.66 76.94 97.70 120.27
6250 31.90 54.09 77.56 98.48 121.24
6300 32.15 54.52 78.18 99.27 122.21
6400 32.66 55.39 79.42 100.85 124.15
6500 33.17 56.25 80.66 102.42 126.09
6600 33.68 57.12 81.90 104.00 128.03
6800 34.70 58.85 84.38 107.15 131.91
7000 35.72 60.58 86.86 110.30 135.79
7200 36.74 62.31 89.35 113.45 139.67
7400 37.76 64.04 91.83 116.61 143.55
7500 38.27 64.91 93.07 118.18 145.49
h23a
200 1.02 1.82 2.56 3.26 4.16
400 2.04 3.64 5.11 6.53 8.31
600 3.06 5.45 7.67 9.79 12.47
800 4.08 7.27 10.23 13.06 16.63
1000 5.10 9.09 12.79 16.32 20.78
1200 6.12 10.91 15.34 19.59 24.94
1400 7.14 12.72 17.90 22.85 29.10
1600 8.17 14.54 20.46 26.11 33.25
1800 9.19 16.36 23.01 29.38 37.41
2000 10.21 18.18 25.57 32.64 41.57
2200 11.23 19.99 28.13 35.91 45.72
2400 12.25 21.81 30.68 39.17 49.88
2600 13.27 23.63 33.24 42.44 54.04
2800 14.29 25.45 35.80 45.70 58.19
3000 15.31 27.26 38.36 48.96 62.35
3200 16.33 29.08 40.91 52.23 66.51
3400 17.35 30.90 43.47 55.49 70.66
3600 18.37 32.72 46.03 58.76 74.82
3800 19.39 34.53 48.58 62.02 78.98
4000 20.41 36.35 51.14 65.29 83.13
4200 21.43 38.17 53.70 68.55 87.29
4400 22.45 39.99 56.25 71.81 91.45
4600 23.47 41.80 58.81 75.08 95.60
4800 24.50 43.62 61.37 78.34 99.76
5000 25.52 45.44 63.93 81.61 103.92
5200 26.54 47.26 66.48 84.87 108.07
5400 27.56 49.07 69.04 88.14 112.23
5600 28.58 50.89 71.60 91.40 116.39
5800 29.60 52.71 74.15 94.66 120.55
6000 30.62 54.53 76.71 97.93 124.70
6200 31.64 56.35 79.27 101.19 128.86
6250 31.90 56.80 79.91 102.01 129.90
6300 32.15 57.25 80.55 102.82 130.94
6400 32.66 58.16 81.82 104.46 133.02
6500 33.17 59.07 83.10 106.09 135.09
6600 33.68 59.98 84.38 107.72 137.17
6800 34.70 61.80 86.94 110.99 141.33
7000 35.72 63.62 89.50 114.25 145.49
7200 36.74 65.43 92.05 117.51 149.64
7400 37.76 67.25 94.61 120.78 153.80
7500 38.27 68.16 95.89 122.41 155.88
f22b1 and 5th gen coupes
200 1.07 1.96 2.99 3.80 5.17
400 2.14 3.92 5.98 7.60 10.35
600 3.22 5.88 8.97 11.40 15.52
800 4.29 7.84 11.97 15.20 20.70
1000 5.36 9.80 14.96 19.00 25.87
1200 6.43 11.76 17.95 22.80 31.05
1400 7.50 13.72 20.94 26.60 36.22
1600 8.58 15.68 23.93 30.39 41.40
1800 9.65 17.64 26.92 34.19 46.57
2000 10.72 19.60 29.91 37.99 51.75
2200 11.79 21.55 32.91 41.79 56.92
2400 12.86 23.51 35.90 45.59 62.10
2600 13.93 25.47 38.89 49.39 67.27
2800 15.01 27.43 41.88 53.19 72.45
3000 16.08 29.39 44.87 56.99 77.62
3200 17.15 31.35 47.86 60.79 82.80
3400 18.22 33.31 50.85 64.59 87.97
3600 19.29 35.27 53.84 68.39 93.15
3800 20.37 37.23 56.84 72.19 98.32
4000 21.44 39.19 59.83 75.99 103.50
4200 22.51 41.15 62.82 79.79 108.67
4400 23.58 43.11 65.81 83.59 113.85
4600 24.65 45.07 68.80 87.38 119.02
4800 25.73 47.03 71.79 91.18 124.20
5000 26.80 48.99 74.78 94.98 129.37
5200 27.87 50.95 77.78 98.78 134.55
5400 28.94 52.91 80.77 102.58 139.72
5600 30.01 54.87 83.76 106.38 144.90
5800 31.09 56.83 86.75 110.18 150.07
6000 32.16 58.79 89.74 113.98 155.25
6200 33.23 60.75 92.73 117.78 160.42
6250 33.50 61.24 93.48 118.73 161.71
6300 33.76 61.72 94.23 119.68 163.01
6400 34.30 62.70 95.72 121.58 165.60
6500 34.84 63.68 97.22 123.48 168.18
6600 35.37 64.66 98.72 125.38 170.77
6800 36.44 66.62 101.71 129.18 175.94
7000 37.52 68.58 104.70 132.98 181.12
7200 38.59 70.54 107.69 136.78 186.29
7400 39.66 72.50 110.68 140.58 191.47
7500 40.20 73.48 112.18 142.47 194.06
theres a really good spreadsheet somewhere on another site. I did these in excel myself.
Old Jun 17, 2002 | 01:43 PM
Default Re: Accord trannys... (TypeSH)
cool, i couldnt import it in
Old Jun 17, 2002 | 01:45 PM
well if you have enough power then top speed would come in 5th gear but in reality most cars cannot get there in top gear
Dodge Viper or a Lingerfield vette can though
evans
Feb 20, 2006 10:26 AM
wayne braley
Oct 19, 2005 06:11 PM
YRMed85
Sep 23, 2005 01:57 PM
Ideal
Aug 3, 2002 06:48 PM
JimmyT89
Apr 26, 2002 07:36 AM
