Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
rsx sway bar question
Old Sep 11, 2007 | 09:33 AM
RA062224's Avatar
Default rsx sway bar question
Old Sep 11, 2007 | 09:37 AM
oddmut's Avatar
Default Re: rsx sway bar question (bakerboy0642)
you'll probably just need to buy a bigger bushing and get polyeurothane and just grease it up.
Old Sep 11, 2007 | 09:38 AM
OSK Automotive's Avatar
http://www.geocities.com/bellz....html
If the bar comes with bushings (aftermarket or oem) it's a bolt on. If it doesn't you'll have to get some.
Old Sep 11, 2007 | 09:48 AM
Default Re: (bakerboy0642)
Then you'll have to buy some bushings like I said.
Old Sep 11, 2007 | 10:03 AM
InanimateCarbonRod's Avatar
Default Re: (OSK Automotive)
The Energy Suspension 3/4" poly bushings and brackets fit.
Old Sep 11, 2007 | 07:49 PM
Jon Vito's Avatar
energy suspension bushings are like 7 bucks for the pair. and the stock brackets work with em
Old Sep 11, 2007 | 08:10 PM
baiwldrnner's Avatar
I drive a '01 LX coupe. I wonder if a rsx rear sway bar can bolt on, maybe with a subframe.
Old Sep 12, 2007 | 06:21 AM
Vantage's Avatar
Default Re: (baiwldrnner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baiwldrnner &raquo;</TD></TR><TR><TD CLASS="quote">I drive a '01 LX coupe. I wonder if a rsx rear sway bar can bolt on, maybe with a subframe.</TD></TR></TABLE>
No, as you drive an 01 LX, you dont not have a stock rear swaybar. The best option is to buy the progress 22mm rear sway bar + adapter kit. The kit comes with threaded nut inserts you will have to drill into the rear crossmember, which provides mounting locations for the 2 main mounting points for the rear sway. It also comes with u bolts to attach it to each LCA? i think it was the LCA.
Regardless, i bought mine a while back off dezod.com and i love it.
Old May 22, 2008 | 11:12 AM
campbuds's Avatar
What options are there for sway bars on a 02 EX?
Are there OE bars from Honda or Acura that are a good way to go or do I need to go after market.
I am taking delivery on the car tomorrow and was wondering.
Old May 22, 2008 | 11:16 AM
toyomatt84's Avatar
Sanji
Default Re: (campbuds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by campbuds &raquo;</TD></TR><TR><TD CLASS="quote">What options are there for sway bars on a 02 EX?
I am taking delivery on the car tomorrow and was wondering.</TD></TR></TABLE>
As stated in this thread, you can run the RSX rear anti-sway without problems.
Old May 24, 2008 | 06:37 AM
campbuds's Avatar
Default Re: (toyomatt84)
I understand... kinda.
On here it said a 02 LX needed holes drilled and stuff. What about an 02 EX?
On my GSR I needed a kit to put the ITR bar on it.
On my 02 EX what do I need to do? What is the size difference (how big is mine and how big is the RSX)?
Old May 24, 2008 | 07:44 AM
LatinEM2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by campbuds &raquo;</TD></TR><TR><TD CLASS="quote">I understand... kinda.
On my 02 EX what do I need to do? What is the size difference (how big is mine and how big is the RSX)?</TD></TR></TABLE>
You don't need anything special on a EX, just on the lower models. I think the stock EX rear sway bar is 13mm and the Type S is 19mm. You can even add a DC5R rear sway bar without any trouble.
Old May 27, 2008 | 06:34 PM
katzenjammer84's Avatar
Any swaybar 23mm and below will work. Anything more and it will not clear the stock muffler.
Old May 28, 2008 | 03:58 AM
campbuds's Avatar
Which OE RSX rear sway bar is bigger than the 19mm bar?
EDIT ... The '05 RSX type S bar will bolt up to my 02 EX 4dr? I read that this is a 21mm bar.
I just need bushings and no brackets right or do I need brackets too?
Modified by campbuds at 1:04 PM 5/28/2008
Old May 28, 2008 | 12:18 PM
Boilermaker1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by campbuds &raquo;</TD></TR><TR><TD CLASS="quote">Which OE RSX rear sway bar is bigger than the 19mm bar?
Modified by campbuds at 1:04 PM 5/28/2008</TD></TR></TABLE>
In 05 they went to a 21mm rear bar. The ITR is a 22mm bar.
You need OEM acura bushings that fit the bar, or energy suspension poly ones of the correct diameter. If you use ES ones, they should come with paired brackets.
gsrvong
Jul 30, 2009 06:23 AM
ssv05civic
Feb 25, 2009 08:34 AM
sloem2
May 3, 2007 05:54 AM
idragen
Feb 18, 2005 04:51 PM
