squeek from suspension???
Old Jun 16, 2002 | 01:46 PM
Ya@inlinePRO's Avatar
Default squeek from suspension???
i got ground controls on koni yellows, slammed to the very bottom, when i go slow about 10 miles over little bumps in parkin lots or what not, it squeek really obvisouly, sounds bad, i think its from coilsovers (sleeves) is there a why to safely lube it to stop this?? thanks guys
Old Jun 16, 2002 | 02:17 PM
neveronlines2k's Avatar
Default Re: squeek from suspension??? (kwik2nec)
Are you sure its not the springs. If the car is that low the coils on the springs could be sitting on top of eachother wich when the move up and down would make them squeak. Mine squeak but I'm used to it. With every mod you do the more sounds you get! At least it seems that way with my car.
Old Jun 16, 2002 | 02:33 PM
95IntegraGSRAZ's Avatar
Default Re: squeek from suspension??? (stuckatworksi)
I had this same problem. When i first put mine on the squeeked for like 1-2 weeks then it was gone. Sometimes it comes back, but i spray the hell out of them with wd-40 and it stop it. I stoped doing that tho, it collected to much dirt on them.
I don't know if that help but
Old Jun 16, 2002 | 02:47 PM
thanks, i'm not sure at all what it is, it could as well be the springs moving, ill try to lube, them but will it be any danger to the lock slippin or somethingl ike that? cause that would suck?
sudds
Suspension & Brakes
Apr 29, 2005 10:47 AM
youngwon22
Sep 18, 2003 08:15 PM
'89 hatch
14
Aug 8, 2002 07:37 AM
mr_jigglesworth
Jun 6, 2002 11:18 AM
