quick ?????
Old Sep 10, 2007 | 07:51 PM
cr-x-91's Avatar
Default quick ?????
i have a 91 si tranny that took a **** on me,i found an 88 si with clutch and flywheel..do i use the cluct and will the axels spline the same as 91 si.
Old Sep 10, 2007 | 08:34 PM
ef-hatchcrap's Avatar
Default Re: quick ????? (cr-x-91)
no you will have to 88 axels if you use the 88 tranny you alsoi need to use the clutch that comes with the tranny
Old Sep 10, 2007 | 08:41 PM
crxnj's Avatar
Default Re: quick ????? (ef-hatchcrap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap &raquo;</TD></TR><TR><TD CLASS="quote">no you will have to 88 axels if you use the 88 tranny you alsoi need to use the clutch that comes with the tranny</TD></TR></TABLE>
lol you don't need to use 88 axles,
use the 88 si tranny,clutch,pressure plate and flywheel on your motor..
Old Sep 10, 2007 | 09:17 PM
garageEF's Avatar
Default Re: quick ????? (crxnj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnj &raquo;</TD></TR><TR><TD CLASS="quote">
use the 88 si tranny,clutch,pressure plate and flywheel on your motor..</TD></TR></TABLE>
x2. you dont need 88 axles, just clutch and flywheel
claytonsmith
Jan 27, 2006 09:08 PM
Gant
15
Feb 17, 2004 03:01 PM
ef9one6
Aug 6, 2003 01:17 PM
KevronsEG
Jan 14, 2003 08:48 AM
CimorelliCRX
16
Dec 12, 2002 05:13 AM
