What cams are good for my K series setup...
Old Sep 10, 2007 | 07:06 PM
Cidone's Avatar
Default What cams are good for my K series setup...
im considering buying cams for my CRX and am wondering what to get... I know IPS cams are one of the best but i dont want to spend the $1600 to get them plus valve train... My signature has my setup and i want to know what you guys have used and gotten good results from..
Im considering
-Skunk2 stage 2s
-Crower
-Brian Crower
-Buddy club
-ect ect
Old Sep 11, 2007 | 02:25 PM
Cidone's Avatar
Default Re: What cams are good for my K series setup... (Cidone)
anyone
Old Sep 11, 2007 | 02:34 PM
modded's Avatar
I would recommend the skunk2 head package
I have had some friends making so serious power using their stuff...
Old Sep 11, 2007 | 02:41 PM
Mhollaek9's Avatar
I hear R Crew makes some crazy cams for k's
Old Sep 11, 2007 | 02:56 PM
Hulk3000x's Avatar
K20a.org should be a little more help imo
Old Sep 11, 2007 | 03:07 PM
Cidone's Avatar
Default Re: (modded)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modded &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend the skunk2 head package
anymore info on the setup your friends were using?
Old Sep 11, 2007 | 04:35 PM
kpowerdhatch's Avatar
Some people have had sucess with the crower K series cams.
I go on k20a.org like said above for my K-series info.
Old Sep 11, 2007 | 09:55 PM
Cidone's Avatar
Default Re: (kpowerdhatch)
ya there was alot of good info on there. whats the biggist lift i can use before there is no enough clearance??? i saw alot of people like the buddy club spec 3s and they are 13mm on intake and 11.8 on exhaust... you cant really go any bigger then that right?
Old Sep 12, 2007 | 07:22 AM
akaRacerX023's Avatar
For a street set up I would go with R-crew which is the same as Buddy Club's but cheaper. I run almost the same set up right now and make 230 to the ground.
Old Sep 12, 2007 | 10:30 AM
Cidone's Avatar
Default Re: (akaRacerX023)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akaRacerX023 &raquo;</TD></TR><TR><TD CLASS="quote">For a street set up I would go with R-crew which is the same as Buddy Club's but cheaper. I run almost the same set up right now and make 230 to the ground. </TD></TR></TABLE>
where can you fine those cams at?
Old Sep 12, 2007 | 11:10 AM
ipodhustle's Avatar
Default Re: (Cidone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cidone &raquo;</TD></TR><TR><TD CLASS="quote">
where can you fine those cams at?</TD></TR></TABLE>
at rcrew
Old Sep 12, 2007 | 12:57 PM
BIGblock97's Avatar
iIPS all the way search http://www.k20a.org
Old Sep 12, 2007 | 03:03 PM
biggie13's Avatar
type r or toda
Old Sep 12, 2007 | 03:31 PM
b20beast978's Avatar
rcrew or ips
Old Sep 12, 2007 | 03:41 PM
909eghatch's Avatar
Default Re: (b20beast978)
Skunk2 or hytech
Old Sep 12, 2007 | 10:00 PM
Cidone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 &raquo;</TD></TR><TR><TD CLASS="quote">rcrew or ips</TD></TR></TABLE>
Im not trying to spend over a $1000 on cams... i mean maybe if i had like a $4000 motor then yes i would but its a street car i want to keep in simple... i think im going to go with some Brian Crowers.. anyone have good comments about these cams?
Old Sep 13, 2007 | 05:25 AM
bobbybo213's Avatar
buddy club or skunk2
Old Sep 13, 2007 | 05:23 PM
ipodhustle's Avatar
Im not trying to spend over a $1000 on cams... i mean maybe if i had like a $4000 motor then yes i would but its a street car i want to keep in simple... i think im going to go with some Brian Crowers.. anyone have good comments about these cams?</TD></TR></TABLE>
brian crower makes some good ****.
he broke off his original company (Crower) because he wanted things run a certain (better) way. his cams are really cheap and you get really good power from them. talk to brian crower personally and that will help you with more info on his cams.
Old Sep 16, 2007 | 04:20 PM
Cidone's Avatar
Default Re: (ipodhustle)
ya ive heard good things as well.. ill be making a a choice soon... anyone have any dyno charts on diff cams
Husain Ali
Jul 2, 2019 09:54 AM
Alan.H-EK4
Oct 1, 2013 02:28 PM
VTECth1s
Apr 13, 2006 02:34 PM
HB1234
Dec 5, 2005 11:23 AM
2ndgent3g
Nov 4, 2004 02:06 PM
