h22 guys...gotta question
Which radiator hoses work with a h22 swap into a civic/integra? I'm running the 92-00 civic dual core radiator if it matters. I heard someone talking about 90-93 teg upper, with 99-00 Si/94-95 del sol b16 lower. Is this correct, or will the 'lude hoses line up??
90 Integra. I could go get one of those flexible hoses, but from experience with them in the past, I don't like the way they look, or perform. The engine is not in the car yet, so I'm not sure how much I'm gonna need, but I'd like to know ahead of time so I could get some genuine Honda or Samco hoses. I'm not cheaping out on anything. I'm not letting a multiple thousand dollar setup fail from a 2 dollar part, you know? Oh, and if it matters, I'm going h2b. I don't see that making too much difference, but info helps.
Half-sized radiator, with slimline fan.
Mine will be different than the 4th gen, because of where the upper hose goes into is further to the right side of the engine bay.
Which lower hose is that? That looks about the same as where mine would go.
Anyone know if the stock lude hoses fit? I just don't want to rig something up...I want it to be a flawless install, that is clean. I'm not bashing, because that setup works, it just doesn't look clean, and looks like you just threw it together. I have an OCD thing where everything has to look professional and clean. And everything has to be done right, or it will bother me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudassVTEC »</TD></TR><TR><TD CLASS="quote">Anyone know if the stock lude hoses fit? I just don't want to rig something up...I want it to be a flawless install, that is clean. I'm not bashing, because that setup works, it just doesn't look clean, and looks like you just threw it together. I have an OCD thing where everything has to look professional and clean. And everything has to be done right, or it will bother me.</TD></TR></TABLE>
I'm not exactly in a position where I can buy H2B hose, so I pretty much HAVE to rig it together
