cams will not turn on new built motor?????
i'm having a problem getting my bc spec 3 cams to turn on my b16 head. i'm running a c5 block with ctr pistons. the block has just been rebuilt and the head is brand new with titanium valves, titanium retainers, 4 angle valve job. the assembly is together with no spark plugs and the cam plates have been torqued to specs and am not able to turn with my hand not even a little bit. has anyone came across this same problem before?
ya well any motor you should be able to turn the cams anyhow whether it be easy or not. please help and advise only
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">A big cam and heavy springs wont turn very easy.</TD></TR></TABLE>TY
Also make sure the belt is good and tight or your T-Belt will be slipping on your cam gears. I ran into that problem with supertech valvetrain. Its a little stiff.
chivid
Jul 14, 2012 08:13 PM
01-DC2R
12
Sep 12, 2007 03:08 PM
blowme
15
May 13, 2005 01:31 PM
crazykid
Oct 25, 2004 01:04 PM
