FS: Balling 93 CX Hatch clean, Buddyclub, Built GSR swap, skunk2, D2, and much more, pics....NORTH C
Old Sep 10, 2007 | 05:15 PM
mugencivic94's Avatar
Default FS:NEW PRICE!!!! Balling 93 CX Hatch clean, Buddyclub, Built GSR swap, skunk2, D2, and much more, pi
Year:1993
Make:Honda
Model: Civic
Trim: CX
The story to the car is, I purchased it from its original owner about 2 months ago. She had the car in durham all its life and garage kept it. Since Ive owned the car its always been garaged also. Very Clean car No DENTS AT ALL. These are the straightest panels you will ever find. Clean paint and immaculant interior as well. Full Back interior including mint floormats. Now to the mods.
Me and a couple of my close friends have Performed every Mod to the car so I can assure you no corners were cut and everything was done right.
Exterior: All mods have less than 500 miles
-Brand new BuddyClub P1 wheels
-New Kuhmo tires
-Oem Style Foglights
-No Dents or Dings No rust cleanest body ive ever seen I would rate it a 9 out of ten
Interior:
-05 Acura Type S seats Black Leather
-95 Acura GSR Gauge Cluster
-Razo Shift ****
-Skunk 2 Short Throw with New Bushings and New bushings on Linkage
for that firm feel.
-No Name CD player that was Previously Installed
- No Cig burns rips or tears at all the interior is a 9.8 out of 10
Suspension:
-D2 Coilover Kit Purchased New as well less than 500 miles on them
-Omni Power LCA's Less than 500 miles on them as well
-Password Three point upper strut bar
-Skunk 2 rear upper strut bar (not installed)
-C pillar bar (not installed)
-GSR Front and Rear Brake Conversion
-Drilled and Slotted Rotors
-Hawk Pads
Engine Management:
-Chipped and Tuned P73 with S200 Hondata
Engine: Block.
- B18C1 Block Bored .20 over
- JE 12.5.1 Pistons
- Carillo Rods with ARP rod bolts
- Block guard
- Cometic head gasket
- Balanced and blue printed crank
- New ACL race bearings all around
- Unorthodox Light wieght Crank and Alternator Pullys
- Rage Header
- Mandrell bent one peice piping to a stealthy flat black Vibrant Muffler
2.5in all the way back
- Hasport Billet extremely Stiff mounts
- Fluidyne Radiator
- Slimline Fan
- Samco Radiator Hoses
- Moroso Oilpan
Engine: Head
-ENDYN P&P PR3 b16 Head
-3 Angle Valve Job
-Skunk2 valves/springs/retainers/valve seals
-Skunk2 Stage II cams
-Skunk2 Intake manifold port matched to the head and to the 68mm Skunk2 Throttle Body
-RC 370cc Injectors
-BDL Fuel Rail
-BDL Oil seal
-Skunk2 Cam gears
-Type R Valve Cover
-NGK blue wires
-NGK iradium plugs
-AEM Type R Cold Air Intake
-MSD Blaster coil with distributor
-Spoon Oil Cap
-Type R Throttle Cable
-Walbro 190 Fuel pump
-New Honda Oil Pump with Toda Gear
-Greddy Timing Belt
Tranny:
-GSR Y80 Tranny with Type R Diff and LSD
-Excedy 6 Puck Unsprung Race Clutch
-Fidanza light weight Flywheel
The Motor was broken with striaght 30 weight and ever since has only seen royal purple 5w 30 and also used the royal purple tranny fluid. The brakes and been flushed and have new fresh fluid and same with coolant. The car runs great but I have some bills i have to get paid so i have to get rid of some of the toys. The car has no issues other than the oil pan has a plug i guess i you wanted to hook up a line for a turbo setup (it came that way from moroso) and it leaks and little i just dont have a bigg enough alan key to fit it. and because the Greddy belt is a little tighter than factory it makes the cam gears a lil noisy. But im just picky.
The Engine bay has been resprayed a Green with gold pearl. I resprayed it before I put the swap in but the rest of the car is factory white, i planned on repainting the whole car this green but ive run into some finacial issues that i need to take care of.
NEW PRICE !!! $7200 as it sits
Forgot to mention it has a clean title and heres some pics And its got a JDM_Kid wire tuck and a new battery
Modified by mugencivic94 at 1:23 PM 9/19/2007
Old Sep 11, 2007 | 03:28 AM
bump
Old Sep 11, 2007 | 03:30 AM
FFEG6's Avatar
Bump for your clean car sir, You just want to sell outright probably, no trades huh.
Old Sep 11, 2007 | 06:17 AM
liltoua's Avatar
how much power are you making on that set up?
Old Sep 11, 2007 | 02:12 PM
Default Re: (liltoua)
on a conserivative tune before the time gears and new exhaust setup it put down 202 whp and 140 torque. so now that it can have the timing tuned more and the better exhaust it should put down another 10 -15 i would guess.
Old Sep 12, 2007 | 03:13 AM
Default Re: FS: Balling 93 CX Hatch clean, Buddyclub, Built GSR swap, skunk2, D2, and much more, pics....NOR
TTT
Old Sep 12, 2007 | 05:36 PM
bump
Old Sep 13, 2007 | 03:38 PM
trujdmek's Avatar
http://hondamarketplace.com/zerothread/2097132
Old Sep 13, 2007 | 04:02 PM
Default Re: (trujdmek)
pmd
Old Sep 14, 2007 | 11:16 AM
now considering trades if cash is on your end i really dont want to get rid of this car its immaculant but at the same time im tired of stressin over bills lets see some offers
Old Sep 17, 2007 | 03:30 AM
the price is obo make some offers
mugencivic94
Oct 4, 2007 03:06 PM
mugencivic94
Southeast (Sales)
Oct 3, 2007 03:14 PM
