car bogs and white smoke comes out...
Old Jun 16, 2002 | 12:42 PM
Maximo's Avatar
Default car bogs and white smoke comes out...
well i took it out again to see if the problem was still there....idle sounds like an exhaust leak near the header........car runs fine and idles fine but when i accelerated and hit 4000 rpm it boged and i lost all power and then big cloud of white smoke came out my tail pipe once i let off the gas it went back to being fine....now i havent sprayed since thursday and it only started boggin yesterday.....could this be a head gasket or a piston problem??
only things ive done lately was install a fuel pressure guage and a high flow cat....and no the engine light never came on
thanks
Old Jun 16, 2002 | 01:00 PM
g2teg's Avatar
Default Re: car bogs and white smoke comes out... (NXTEG)
I wonder if you burnt your head gasket or piston rings. Nitrous gets pretty hot for stock gaskets. Try to smell the smoke(don't try to get high off of it) check if it smells like you are burning oil. That might be something to check...although it might not be an easy fix.
Old Jun 16, 2002 | 01:02 PM
flymecourageously's Avatar
New User
white smoke and bogs souns like coolant leaking into combustion chamber .do a compression test or just go straight to the leak down
Old Jun 16, 2002 | 01:37 PM
Maximo's Avatar
Default Re: car bogs and white smoke comes out... (flymecourageously)
should mention that car runs fine except at WOT......and it is only like 10 degrees today so all smoke is white....doesnt smell like anything burnt.......and i havent sprayed since last thursday........so i would imagine something like that would happen while spraying and not daily driving.......
Old Jun 16, 2002 | 05:13 PM
Chiovnidca's Avatar
What does your oil level look like? Is it overfilled?
Old Jun 16, 2002 | 05:55 PM
Maximo's Avatar
Default Re: car bogs and white smoke comes out... (Chiovnidca)
i just rolled 5000k so its about 3/4 and still gold.....which is normal
if i turn it on cold and take off the rad cap it and it bubbles its the head gasket ??
Old Jun 16, 2002 | 06:30 PM
StyleTEG's Avatar
Is there a milky white substance on the bottom of your oil cap?
Old Jun 16, 2002 | 06:46 PM
Maximo's Avatar
Default Re: car bogs and white smoke comes out... (StyleTEG)
nope why???
Old Jun 16, 2002 | 06:50 PM
Chiovnidca's Avatar
Probably.
Old Jun 16, 2002 | 06:53 PM
Maximo's Avatar
i didnt do it cause its dark out but i will tommorow morning.....just tryin to save on diagnostic time.....put him in the right direction.....
Old Jun 16, 2002 | 07:51 PM
StyleTEG's Avatar
nope why???
Often a result of coolant mixing with the engine oil
Old Jun 17, 2002 | 08:20 PM
Maximo's Avatar
problem is....
after 3 days of heavy downpour and driving my aem cai seems to have sucked in quite a bit of water.....compression is between 185 and 195 all across and the oil change seems to have cured it
thanks for the help boys glad it was only a small problem
project ak
Jul 28, 2006 03:00 AM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
3rd gear vt3kc pullz hard
Jan 25, 2004 03:36 PM
22boost
Jan 15, 2004 09:42 AM
Randomlude
Oct 12, 2002 03:56 PM
