Junkyard d-stroker
Old Sep 10, 2007 | 02:10 PM
92BluEH-3's Avatar
lulz
Default Junkyard d-stroker
alright i saw a picture of the cover of a honda tuning magazing with the white dc5 with the gold plated v/c and itb's and it said on the lower right side of the cover "stroke your d-series using junkyard parts. i was looking on the hondatuning website to try to find the article about stroking your d-series with junkyard parts, if anyone has a link to this article that would be great, thanks.
Old Sep 10, 2007 | 02:18 PM
LessRice's Avatar
Default Re: Junkyard d-stroker (92BluEH-3)
i read that article it was in last months... i think... but anyways it is definately not worth the effort to get what they produced but i guess thats just me because i can only have two projects
Old Sep 10, 2007 | 02:29 PM
92BluEH-3's Avatar
lulz
Default Re: Junkyard d-stroker (LessRice)
well this is my only project car, did it involve uber machining and what not? any link?
Old Sep 10, 2007 | 02:32 PM
Syndacate's Avatar
Buy the motor from the '96-'00 Civic GX's - they use natural gas and have some ridiculous (like 12:1) CR. Slap a Y8 manifold and trimmings (fuel rail, injectors, TB, etc.) - and you have yourself a 12:1 CR D series.
Bense could give you more details including how not to set the dizzy timing correctly and blow the motor .
Old Sep 10, 2007 | 02:35 PM
92BluEH-3's Avatar
lulz
Default Re: Junkyard d-stroker (Syndacate)
well my single is already up around close to 11:1 or so i havnt really worked it out, but i figuered i would see how they did it and if it was worth my time or not
Old Sep 10, 2007 | 02:37 PM
instrument's Avatar
order the back issue.
Old Sep 10, 2007 | 02:40 PM
92BluEH-3's Avatar
lulz
Default Re: (instrument)
where would i be able to do that? i suck at the internot
Old Sep 10, 2007 | 03:29 PM
samba_green_sol's Avatar
5 dollars shipped i have it
Old Sep 10, 2007 | 06:13 PM
khrisb's Avatar
Default Re: (samba_green_sol)
I think they finagled a D17 crank in there somehow with GX pistons. I think they had to notch the block for the crank to fit. It really didn't seem worth the trouble though. Thats what the guy said at the end of the article. They did that for the specific class event they were doing. It had to be OEM parts, but you could build whatever you wanted with them. No swaps.
Old Sep 10, 2007 | 06:18 PM
hondamark35's Avatar
Default Re: (92BluEH-3)
yeah it seams pretty involved if this is your only car and not a project car. there were some fabricating/modifications that could go horribly wrong if you aren't proficient in the area of engine building.
i think it's a super cool build, the gains weren't amazing but if i did it it would be more for the fun of knowing what i did to make the power.
Old Sep 10, 2007 | 06:31 PM
fsteclipsegst01's Avatar
i read that article while i was taking a **** at work :-)
Old Sep 10, 2007 | 07:56 PM
lemon_juice's Avatar
Default Re: (hondamark35)
if i remember that dyno showed it made power!
basically all it is doing is modifying a 1.6 block to fit a 1.7 crank(notches in the block). you use th same rods (137mm) but also the 1.7 pistons (namely the gx for higher compression). to do that, the cut valve reliefs into the piston because they dont come with them(needed because they planned for a big cam).
if you know what your doing, this machining can be done by yourself without costly machine work. compare it to boring a block, itll be cheaper. also, the oem parts are cheaper if found in a junyard.
Old Sep 11, 2007 | 05:27 AM
92BluEH-3's Avatar
lulz
Default Re: (lemon_juice)
hmmm seems like a ridiculous amount of work, did they post a dyno sheet at all? or a final whp?
Old Sep 11, 2007 | 08:43 AM
Chim Chim's Avatar
It made 170~ish WHP but they ended up with 165~167 WHP for a better torque curve.
Old Sep 11, 2007 | 09:10 AM
built562's Avatar
Default Re: (Chim Chim)
isnt there another way to stroke a D-series using ls rods or something like that.
<-------knows nothing about d-series engines!
Old Sep 11, 2007 | 09:53 AM
roycivic92's Avatar
Default Re: (built562)
i think they used a 1.7 crank from a newer civic .
Old Sep 11, 2007 | 06:29 PM
92BluEH-3's Avatar
lulz
Default Re: (roycivic92)
most ppl use the ls rods for boosting i havnt checked the specs to see if it actually strokes it out, i would think it would
Old Sep 11, 2007 | 06:31 PM
drtysohc's Avatar
it isn't worth it.
Shawn_71288
Jul 5, 2012 04:19 PM
faxshatch
Apr 3, 2008 06:18 PM
og_hatch_90
Nov 18, 2005 02:53 AM
B_CRUZ!
Apr 4, 2002 02:19 PM
Malgerus
Mar 31, 2002 09:42 PM
