IACV Wiring Diagram
Old Sep 10, 2007 | 01:57 PM
DrewMD's Avatar
Davis Photography
Default IACV Wiring Diagram
This was pulled from the haynes manual:
The yellow circle is the Idle Air Control Valve, which is what im having trouble with. The last time I tried to figure this out I soldered my wire connections and the problem didn't occur for about a month. Now the problem has returned and will only occur if I sit there and idle, waiting at a light, etc.
I was gonna run two new wires, one to the ecu and one as the ground, which gets bunched with other wires and eventually leads to the Main relay. The part that says junction connection, which is circled in red, is that a plug that I can run the new wire to? or would I have to trace it all the way back to the main relay?
Old Sep 10, 2007 | 02:04 PM
sicones's Avatar
Default Re: IACV Wiring Diagram (DrewMD)
there are 2 big junction connectors under the intake manifold (they look like plugs with caps on them), you will see all the yellow and black wires go there
Old Sep 10, 2007 | 07:46 PM
DrewMD's Avatar
Davis Photography
Default Re: IACV Wiring Diagram (sicones)
will it be as easy as depinning it?
Old Sep 11, 2007 | 09:53 AM
sicones's Avatar
well, I would find out why the blk/yel wire isn't properly grounded, and trace the other wire back to the ecu and make sure it has a good connection
bust out the multimeter
Old Sep 11, 2007 | 11:36 AM
DrewMD's Avatar
Davis Photography
will do. ill have to borrow one.
wickedEFguy
May 20, 2020 03:51 PM
everlight44
Sep 8, 2008 08:17 AM
3.point.2
Feb 2, 2006 01:02 PM
Tex Blackwell
Nov 24, 2004 07:35 AM
Alstare
Sep 25, 2002 09:11 PM
