------DOES SOMEBODY WANT TO HELP ME WITH MY PROJECT H22A IN A EG-------
I NEED TO KNOW WHAT HARNESS CAN I USE ON THIS PROJECT IM PUTTING THIS ENGINE IN MY CAR BUT ITS MISSING THE HARNESS WHAT HARNESS CAN I USE TO RUN MY CAR AND ECU,.. ANY HELP OR COMMENT WOULD BE GOOD THANKS..................
What kind of "eg" is it?
You can modify your existing harness, or use the h22 harness and get a jumper cable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">Hahaha... I had to save that.
Look at the H22 FAQ in the Hybrid section. It has a complete walk through of your options
The stock harness is fine.
ANY harness you can put your hands on for '92-'00 (or '01 'teg).
It'll be a bit easier if you get a harness that's the same OBD as your car, but any will work. Might have to do a few plug transplants - but they're just color matching.
If it's not for the H22 you'll have to do a IAB wire-up...anything u get ur hands on is fine, it's easy to add in wires.
