"FS: 1989 Honda Civic LX Sedan - B16a, show winner"
Old Sep 10, 2007 | 11:12 AM
KaBlookie's Avatar
Default FS: 1989 Honda Civic LX Sedan - B16a, show winner
NOTE: I AM SELLING THIS CAR FOR A FRIEND. HIS CONTACT INFO IS LISTED, SO CONTACT HIM WITH QUESTIONS. You can PM me if you'd like, but I"ll just relay it to him.
Vehicle has been lovingly maintained and customised, with professional installations on all aftermarket accessories. Car runs terrifically and regularly gets well in excess of 30mpg on the highway! The perfect combination of performance and reliability! A full list of modifications follows...has been called the fastest '89 four door on the east coast! 100% emissions certified in Massachusetts. Simply put, the car was designed to be as adjustable as possible. One of the most livable sport compact cars out there, the car has been daily driven and impeccably maintained.
Certainly quite a few modifications! Realistically as far out as this car can be taken, drivability was always a primary concern for me, and it remains a true drivers car while at the same time delivering true sports car performance. Better power to weight ratio than an R34 Skyline and BMW E46 M3!!
As far as the mileage goes, only the chassis itself has seen 141,000 miles. The engine and transmission both had 15,000 at time of purchase and have roughly 40,000 on them now. Other parts have only limited mileage and work impeccably! If one so wishes, the car can be further customised to be even faster, but fuel mileage and drivability would suffer. Test drives will be offered as desired. No warranty existing or implied. Feel free to contact me for details or with any questions or concerns! As the car's literal designer, I can answer all of them!
SHOW HONORS:
- Hot Import Nights Feature 2004 (Boston)
- Carandmodel.com feature 2004
- Class Winner: Toyo Tires Import Wars-06/23/07
- Runner-up: Toyo Tires Import Wars-2004, 2005
<u>MODS:</u>
Engine:
- 1.6L JDM B16A DOHC VTEC
- Hasport Motor Mounts
- Spoon Cams
- AEM Cold Air Intake w/ Bypass Valve
- B&M Adjustable Fuel Pressure Regulator
- Walbro 255lph High Flow Fuel Pump
- Custom Engine Harness
- B&M Fuel Pressure Gauge
- Custom Painted Valve Cover
Exhaust:
- Jasma Certified JDM Header, 2.5in Collector
- Magnaflow 2.5in Hi-Flow Catalytic Converter
- Custom Header-Back 2.5in Exhaust System
- Flowmaster Muffler
- Magnaflow Exhaust Tip
Drivetrain:
- ACT Stage 1 Clutch
- 5-speed Manual Transmission from G3 Integra GS-R
- Pacesetter Adjustable Short Throw Shifter
- Shifter Stabilizer Bushings
Ignition:
- MSD Blaster 2 External Ignition Coil
- Crane Cams Distributor Cap and Rotor
- Custom Mounted CRX Si VTEC Distributor
- NGK Spark Plug Wires
- NGK V-Power Spark Plugs
Suspension:
- Skunk2 Adjustable Coilovers
- Tokico Illumina Shocks
- SPC Adjustable Front Camber Kit
- Prothane Bushing Kit
Brakes:
- Powerslot Slotted Rotors
- EBC Brake Pads
- Painted Calipers (Red)
Rims/Tires:
- Motegi FF7 Rims (17x7in)
- Toyo Proxes FZ4 Tires (205/40/ZR-17)
Exterior:
- VIS Racing Full Body Kit
- VIS Racing Z3 Fenders
- StreetGlow L.E.D Underbody Kit (Blue)
- APC Front Grille
- Custom Silver Paint
- Locking Hood Pins
I.C.E:
- Alpine Head Unit
- Two Pioneer 10” Subwoofers
- Custom Enclosure in Trunk
- Streetglow Trunk Accent Neon
- Pioneer 6x6 Component Speakers
- Tsunami Wiring Package
Interior:
- Ractive Racing Seat
- Ichibahn Pedals
- DC Sports Shift ****
- Autometer 5” Tachometer w/ Shift Light
- Autometer Pillar-Mounted Voltmeter
- Autometer Pillar-Mounted Oil Pressure Gauge
- Grant Steering Wheel
Car is located in NE Massachusetts.
Asking $4,995 OBO
Question, offers, comments, etc. send an email to: christopherjsmith01@gmail.com
Modified by KaBlookie at 1:43 PM 9/10/2007
Old Sep 12, 2007 | 06:52 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Old Sep 12, 2007 | 10:08 AM
Ep1dem1c's Avatar
Default Re: (ComeOnKip)
Old Sep 13, 2007 | 08:21 AM
bleedblue94's Avatar
Default Re: (Ep1dem1c)
Old Sep 14, 2007 | 02:22 PM
b16civster's Avatar
Default Re: (bleedblue94)
show winner or show wiener
Old Sep 17, 2007 | 09:21 PM
KaBlookie's Avatar
Right...nobody's asking for your opinions on this car, so if you're not interested and are just going to negatively comment on it, please just be mature and not post anything. It's not appreciated, nor does it do anybody any good.
If you're interested or have real questions, contact me or the seller.
Old Sep 18, 2007 | 04:46 AM
ComeOnKip's Avatar
In all seriousness tho, if you can't sell the car i'll come pick up the engine/trans from you if you wanted to sell that.
DJ Alex
Oct 14, 2009 09:56 PM
colnago
Jun 24, 2009 07:38 AM
compuvision02
Jul 29, 2008 05:13 PM
KaBlookie
Oct 27, 2007 07:48 PM
