Smokes a little after starting in engine bay, black sut spitting out of exhaust, irratic idle
Old Jun 16, 2002 | 11:56 AM
2camsaam's Avatar
Default Smokes a little after starting in engine bay, black sut spitting out of exhaust, irratic idle
I just installed my old stock motor in my car. My other motor which what turboed was just taken out to be rebuilt. After installing my old motor back in, here are the symptoms: Smokes a little after starting in engine bay, black sut spitting out of exhaust, irratic idle (between 800 and 1200rpms).
Please help me out.
Old Jun 16, 2002 | 11:57 AM
tooqwik1's Avatar
Default Re: Smokes a little after starting in engine bay, black sut spitting out of exhaust, irratic idle (S
what color smoke?
Old Jun 16, 2002 | 12:32 PM
2camsaam's Avatar
the smoke is white/grey
Old Jun 16, 2002 | 12:34 PM
rodrez.'s Avatar
The smoke in the engine bay could just be burn off, maybe you spilled some oil or coolant on the manifold, or a hot spot on the block, or maybe you have an exhaust leak where the manifold and cat connect. Try to calm the idle down using the screw on the throttle body.
Old Jun 16, 2002 | 02:31 PM
2camsaam's Avatar
Think i fixed it .
I used compressed air to spray the connections for the harness on the radiator, then the connections on the IACV. I reconnected them both. Started the car and the car ran a little bit better. I then disconnected the map sensor plug and the car turned off, (i thought to myself maybe I should not have done that), i then sprayed the connections with compressed air and plugged it back in.
I started the car again and it idled perfectly.
2a5x1
Nov 28, 2008 03:37 PM
g2tegsown
13
Jul 3, 2007 12:37 PM
fraknstien
Mar 6, 2007 11:05 AM
Speed Monkey
Honda S2000
Dec 17, 2006 07:54 AM
JDMtype Eg6
Mar 21, 2006 01:33 PM
