getting EG bolts loosened
Old Sep 10, 2007 | 10:57 AM
phatfrenchy413's Avatar
Default getting EG bolts loosened
for the eg's are all of the bolts all over the car close to impossile to loosen and get off. ive had trouble with every bolt ive tried to get off
Old Sep 10, 2007 | 11:01 AM
instructor74's Avatar
Default Re: getting EG bolts loosened (phatfrenchy413)
its called a 10+ year old car all the bolts that are in the elements are going to rust and seize. So yes it can be a real pain in the *** get a good penetrating lube like PB Blaster, you can also try heating the bolt up. Be prepared to replace a good many of the bolts also get yourself a bottle of antiseize for when you are putting things back together again
Old Sep 10, 2007 | 11:46 AM
instrument's Avatar
you have a 10 year old car in Wisconsin!
i think it snows there.
Old Sep 10, 2007 | 01:08 PM
bgcrx's Avatar
Default Re: (instrument)
Air compressor, impact gun. done.
Old Sep 10, 2007 | 01:14 PM
gsxr1k05's Avatar
pb blaster, let it sit, impact gun like bgcrx said. and a good *** drill bit for drilling out the broken ones. with a screw extractor set. and while your at it, bitch slap yourself for living in wisconsin with the amount of salt they put on the roads and then wonder why a 10 year old car would have rusted hard to losen bolts.
20CiviC02Si
Mar 30, 2015 08:03 PM
SWC
Suspension & Brakes
May 9, 2006 08:35 PM
civiccoupe94
34
Nov 17, 2005 08:15 AM
oMek
May 6, 2004 01:06 PM
