B16 -91 civic HEADER HELP NEEDED
i know qhwn you swap the b16 into a crx you have to bang the front cross member but can the stock manifold and down pipe fit in a 91 civic hatch back . if not what is the easiest and cheapest way to make it WORK.
a stock or 4-2-1 header will fit w/o problems. If you want to run a 4-1, THEN you have to bang out the crossmember just a bit. you will be 100% fine with your header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Maxidermist »</TD></TR><TR><TD CLASS="quote">It depends on mounts and header, some fit some don't.
It's one of those, you'll know when you are doing it ordeal.</TD></TR></TABLE>
oops, i forgot about all the diff mounts available. If you run Hasport then you'll be fine, thats what I run. it also helps if you front end has never been wrecked, these efs are prett much never the same after bad front end damage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome »</TD></TR><TR><TD CLASS="quote">
oops, i forgot about all the diff mounts available. If you run Hasport then you'll be fine, thats what I run. it also helps if you front end has never been wrecked, these efs are prett much never the same after bad front end damage</TD></TR></TABLE> Tis quite alright and you should just say "theses efs are pretty much never the same." Honestly lol.
I've needed to smash an X member for the same setup in a different car and with one I havn't.. niether were wrecked.
my 90 hatch with a b16a swap has the front crossmember banged in but since i bought it with the swap done i have no idea what mounts the guy used. But it has the stock b16a exhaust manifold.
STP_crx123
Jan 4, 2006 11:32 AM
