Z6 to Y8 swap in SOHC vtec?
Old Jun 16, 2002 | 11:04 AM
HondaPartsHero's Avatar
Technical Hero
Default Z6 to Y8 swap in SOHC vtec?
before i get flamed let me explain, i have never done a cam swap in a sohc, just done some b16 cam swaps, i have a Y8 head layin around and was wondering to get some experience and get a better cam is it worth doin? i am getting a zex cam in 6-10 years(ha, jk i'm low on paper if you know what i mean?) so this will be temporary, thanks heres the specs on both cams
Duration Duration@ .050" Gross lift w/ 1.6 int / 1.8 exh
D16Z 244 / 228 208 / 192 384 / 370
D16Y 246 / 230 208 / 191 393 / 369
i'm not a cam expert so help me out with these specs to see the advantage/gain if any, thanks
Old Jun 16, 2002 | 11:28 AM
Technical Hero
Default Re: Z6 to Y8 swap in SOHC vtec? (yebabee)
ttt
Old Jun 16, 2002 | 11:48 AM
Charlie Moua's Avatar
damn not really sure what your asking bro. be more specific and ask good questions.
Old Jun 16, 2002 | 01:52 PM
JDMBOLONI's Avatar
if your talking about putting a Y8 head on your Z6 block thats what I am doing right now, I got it for free and my old one needed valve seals so it was win win. it raised my compression too so I think if you have a spare one put it on! There were 2 differences between the heads that i found, the vtec solinoid bolts up different and the intake side of the head is a bit different too. but you will be fine as long as you have the vtec solinoid
Old Jun 16, 2002 | 02:13 PM
Technical Hero
Default Re: Z6 to Y8 swap in SOHC vtec? (JDMBOLONI)
sorry was writing in a hurry and didn't have a chance to read my original post. I have a Y8 head complete(needs new valves and seals) is it worth it just to put the Y8 cam in my A6 motor in my car right now. The specs of the two cams are above. I am not sure how much of a difference the longer duration of the Y8 cam would make. Plus i need some practice changing sohc cams out(i've done DOHC VTEC cam installs just not sohc). Thats what it should have said sorry. I am going to build the Y8 head i have right now with a crower or zex cam until then.
Old Jun 16, 2002 | 02:20 PM
BoostedED9's Avatar
i heard that on the y8 head you can bolt up our distributor without having to modify the legs.... it sux b/c i have a z6 and i had to cut the legs of my distributor up to make it bolt up....
Old Jun 17, 2002 | 04:06 AM
Mista Bone's Avatar
D Tranny Guru
just so you know the Y8 and Z6 cams are indexed differently. The stock Y8 cam has a little lift/duration on the low cam, but the high cam specs are the same.
BTW I figure out the cam specs first, just didn't think Honda would re-index the cam keyway.
4potnick
Sep 3, 2006 11:57 AM
dohdoh420
Sep 19, 2005 08:48 AM
eh6
Sep 5, 2004 01:23 PM
e-blue
Nov 2, 2003 08:26 PM
