FS: Fully Built Poor Man's Type R
Old Sep 10, 2007 | 06:32 AM
TypeRHatch93's Avatar
Default FS: Fully Built Poor Man's Type R
Due to financial problems I have to part with my swap.
Swap includes EVERYTHING...
Engine
Tranny
Axles
Linkage
Harness
ECU
and Innovative Mounts *Gray*
Head: B16A2
BDL 70MM TB
Edelbrock Victor X ITM
STR Comp Fuel Rail w/ Fuel Pressure Regulator
ITR Valve Cover
Skunk 2 Stage 2 Cams
Rev Hard Valvetrain
New seals
Rev Hard Intake Valves
AEM Tru Time Cam Gears
Race Port and Polish
Cometic Head Gasket
ARP Head Studs
Block: GSR B18C1
CP 12.5:1 Pistons
Eagle H Beam Rods w/ ARP Rod Bolts
ACL Race Bearings
CTR N1 Crank Pully
ITR Oil Pump
New Water Pump
Balanced WHOLE rotating assembly
Tranny: B16
ACT Xtreme Pressure Plate
ACT 4- Puck Unsprung Clutch Disc
Fidanza 7.5# Flywheel
Everything has been replaced... All Gaskets, Belts, Seals, ETC. Nothing was skipped.
Linkage has Energy Suspension bushings - Black
Harness was re-done for wire tuck COMPLETE re-wrap.
Compression is - 12.9:1
Im still breaking the motor in... it has 125 miles or so on it. Ran 110 Octane through it.
All that remains to make this a high 11 Low 12s car is to get:
Bigger Injectors - I had planned on running E85
Hondata and Tune.
Dont have pictures with the mounts installed... But they are there...
I also have most of the receipts for the parts, and pictures of the build on my phone... If you would like those aswell I can text them to you or I can upload them on my non-work computer haha.
Im asking 6k OBO.
Old Sep 10, 2007 | 07:05 AM
quick bump
Old Sep 10, 2007 | 08:33 PM
Default Re: (TypeRHatch93)
bumpy
Old Sep 11, 2007 | 05:58 AM
morning bump
Old Mar 17, 2008 | 08:56 AM
wowy978's Avatar
Default Re: FS: Fully Built Poor Man's Type R (TypeRHatch93)
u can get a itr swap for 4K hah
hondaclassifieds
Mar 5, 2009 12:53 PM
TypeRHatch93
Texas -OK -LA (Sales)
10
Oct 12, 2007 12:23 PM
TypeRHatch93
Oct 10, 2007 06:38 AM
Viorent Grip! EG
Sep 17, 2007 08:11 AM
hbracer93
May 9, 2007 03:32 PM
