"S" Light 91 Honda Accord LX
Old Sep 10, 2007 | 05:22 AM
rommersk's Avatar
Default "S" Light 91 Honda Accord LX
Hi Everyone,
I have a 91 Honda Accord LX. The “S” Light was intermittently coming on and downshifting the transmission. Now the “S” Light won’t go off and the transmission won’t go out of 3rd gear. Here is what I have done so far:
- Jumped the service check connector, no error code given
- Removed the 7.5A Backup fuse for 1 minute and replaced
- Disconnected and reconnected the positive battery terminal
- Unplugged and inspected the Transmission Control Unit – no visible damage apparent
Any other ideas? I have minimal mechanical/electrical knowledge – please be specific. Thanks for your help!
Old Oct 25, 2007 | 09:13 AM
rommersk's Avatar
Default Re: "S" Light 91 Honda Accord LX (rommersk)
UPDATE
I bought a TCM on ebay for $142 and swapped it out with the old one. Problem solved!
Old Oct 25, 2007 | 11:50 AM
aharrison06's Avatar
What is a TCM? I have the same problem on my 91 accord!
Old Oct 25, 2007 | 12:18 PM
tigerbait's Avatar
Default Re: "S" Light 91 Honda Accord LX (aharrison06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aharrison06 &raquo;</TD></TR><TR><TD CLASS="quote">What is a TCM? I have the same problem on my 91 accord!</TD></TR></TABLE>Transmission Control Module
Old Oct 25, 2007 | 12:47 PM
rommersk's Avatar
Default Re: "S" Light 91 Honda Accord LX (tigerbait)
It is located in the floor under the glove box. Pull up the carpet and it is on the right side of the metal housing. The Engine Control Module (ECM) is on the left side of the housing.
Old Oct 25, 2007 | 06:42 PM
ilikehonda's Avatar
if the s light is green....thats the sport button light baby
Old Oct 26, 2007 | 06:31 AM
Default Re: (ilikehonda)
Thank yall very much!!!!
Old Oct 29, 2007 | 05:21 AM
viotraytray's Avatar
Hi, I also have a 91 Honda Accord and my light won't go off. I know nothing about cars just found this because I don't feel like being ripped off again, so I googled car diagnosis. Anyway my question is, I noted you said you bought a TCM what is the name of this part so I can try to price it and is it something I could put in or is it a difficult part
Old Oct 29, 2007 | 06:50 AM
rommersk's Avatar
Default Re: "S" Light 91 Honda Accord LX (viotraytray)
Go to ebay and search for a Transmission Control Unit for your model car. It is critical that you you get the serial number off the old TCM so you get the right part. Match up the serial number with the serial # on the new unit on ebay before you buy it. Swapping out the old unit is not that difficult. My earlier post has the location. You will need a metric socket (can't remember the exact size - possibly 10 mm?) and an extension for your ratchet. Once you have the housing off, unplug the 2 wire bundles going into the unit and install the new one. Here is the description on my unit - IT MAY BE DIFFERENT ON YOURS.
AT Control Unit
28100-PXO-823-M1 3LX
Lot No. 1603U
OKI Telecom
Good luck.
Old Oct 29, 2007 | 06:51 AM
rommersk's Avatar
One more thing, the housing has 2 modules, the ECM and TCM. The TCM is on the right side.
Old Jan 21, 2011 | 05:36 AM
grantfam's Avatar
Hi, I have a 91 Honda Accord as well and the "S" light is on and off at random. The shift lock stops working at the same time the "S" light is on. Are these both controlled by the TCM or do I have two problems? The TCM was replaced by the privies owner from a salvage yard.
Old Jan 22, 2011 | 02:43 PM
ilikehonda's Avatar
sounds like the TCM. you can have your rebuilt for 100 bucks if you cant find a replacement.
junior91hondaac
Jun 18, 2013 04:37 AM
lildevil6290
Sep 17, 2012 03:05 PM
rommersk
Nov 2, 2007 04:17 AM
