anybody have good reviews of sway bars?
Looking to buy a sway bar and some strut bars for the rex in the near future... any suggestions on the sway bar/reviews on it? Same with the strut bars?
thanks
thanks
Good to hear, I just installed a 19mm off of a 91 4dr onto my 90 STD and it handles much better of course...Going from NO bar to a 19mm front is way better. I used the Energy suspension end link kit, but the 19mm sway bar bushings are on back-order so I just got a set from Honda for now. Also installed their strut rod end bushings I think their called. It was easier to install those first then the end links for the front s/b. I have been looking at the ST rear bar now...
i have my rex lowered with skunk 2 coil overs and energy suspension and tenzo sway bars. my car has no body roll at all. and handles like a dream. if u can get the tires to squel on my car in a turn your going to die in a crash. that is the best setup i have ever seen. of course my car is set up for turns and tracks not drag times. plus it bumps every where.
The ST rear sway bar
Plus it looks wicked...best part is it does it's job and it's adjustable...
You can always adjust the amount of oversteer you want want from the rear.
Modified by MarlonT42 at 3:53 PM 9/10/2007
progress
some what of a pain to install since it doesnt use the factory location...also a lot of washers, spacers, nuts, and brackets.
i had to take off my exhaust for an easier install...also i dont know if this applies to all crx's but the subframe is suppose to have a hole for the bracket but i have an hf and there is no hole so you have to drill a hole and use a special nut also they recommend you get the bracket welded onto the frame.
some what of a pain to install since it doesnt use the factory location...also a lot of washers, spacers, nuts, and brackets.i had to take off my exhaust for an easier install...also i dont know if this applies to all crx's but the subframe is suppose to have a hole for the bracket but i have an hf and there is no hole so you have to drill a hole and use a special nut also they recommend you get the bracket welded onto the frame.
when u guys said ST I meant you meant Skunk2. Whats ST??? Because I am also looking into strut bars, and everyone in here said ST so i would like to know lol.
leave a stock bar on the front and get a aftermarket sway bar in the back. i have used the ST bar out back and love how it is adjustable. tenzo doesnt make sway bars, they make strut bars.
Yea i was leaning towards st before, ive heard nothing but good reviews about them. Im probably gonna order a set soon, and eventually the function and form type 2's to replace my skunk2's..
b16a1, that bar looks sick and your camber looks even sicker.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">What do us folks without a factory bar have to buy?</TD></TR></TABLE>
what do you mean? for rears? the sway bar kit includes everything you need to bolt on the sway bar.
if you wanted the the factory SI rear sway bars it require the use of SI LCAs
ST sway bars use brackets to bolt it on the tow hooks
Anyone have the ASR sway on their ride/care to do a quick review on it? I have the ST 22mm rear and love it (except for the constant 3 wheeling around most corners/slow dips). Don't regret it at all
I'd like to see what people think about the ASR unit though
. I'd like to see what people think about the ASR unit though
Anybody have a pic of how the S/T or the Progress mount in the rear, I want to see how they bolt it to where the rear tow locations were...Also can't the Progress be used on the factory STD and DX LCA's. I thought it mounted to L brackets you installed on your lower shock mounts. My rusted muffler fell off, and I am not having any exhaust work done until I get my rear sway, that way the exhaust guy can bend to his hearts desire to clear the rear sway...
