??After DPFI 2 MPFI Conversion??
Old Sep 9, 2007 | 08:55 PM
HybridHatchEF9's Avatar
Default ??After DPFI 2 MPFI Conversion??
After i did my DPFI 2 MPFI my check engine stays on for the CYL. POS. sensor, all my wiring is correct everythings soldered but here's the thing, the hatch runs fine. I can reset the ECU and doesnt come on at idle till after i hit the throttle then it just stays on. The motor does skips a heartbeat once in a while though, kinda like a misfire but quicker. ***** got me puzzled, ima replace the dis. first, and if that dont werk then ima try the ECU.......PLZZ help and if that dont werk ima just throw the Z6 head on and finally do my mini-me swap
Old Sep 9, 2007 | 09:55 PM
mattcivic's Avatar
Default Re: ??After DPFI 2 MPFI Conversion?? (HybridHatchEF9)
i know u said your wiring is good but when u re-pinned your dizzy plug were u sure it was done right?
double check it even better have a buddy check it as well sometimes a second set of eyes is what ya need
if u need a place to check your work i recomend here
http://www.angelfire.com/d20/h....html
Old Sep 9, 2007 | 09:56 PM
mattcivic's Avatar
Default Re: ??After DPFI 2 MPFI Conversion?? (mattcivic)
BTW i have a spare MPFI dizzy if u need it let me know GL
SeraphimKidd
Jul 8, 2012 12:55 PM
"goose"jay
Feb 23, 2011 01:38 PM
builtsinglecam
Feb 28, 2009 10:58 PM
hfrex
Jan 5, 2009 10:24 AM
crxnonvtec
Aug 19, 2008 03:29 PM
