Throwout bearing bad or clutch/flywheel/pressure plate are cracked ?
Specs: 96 SOHC VTEC Manual EX Tranny.
Driving the car normally going home... Ready to make a turn so downshifting the car to 2nd gear the tranny makes a weird noise almost like metal to metal grinding. So everytime the car is on and the clutch is pressed it feels like metal to metal. If the car is neutral it will shake the motor vigorously ....and almost wants shut off .The motor shakes alot when gears are put in but after clutch is released noise goes away and drives normal.The gears are a little harder and sometimes WONT wanna go in ..The tranny with car off will go into every gear without clutch tranny never grinded or never did it lose any gears.. It takes a little longer to start the car but it still starts.... Re-bled the clutch ....added new fluid to clutch resovoir....checked for leaks in all the lines All that stuff is checked i checked for movement of the throwout bearing ( The fork moves fines from the outside,) Tommrow ima gonna open it up just wondering what you guys would think it would be.
NosCivic01
Apr 25, 2006 03:37 PM
Junkyard2000
11
Dec 20, 2005 11:51 AM
snatch
May 1, 2004 05:45 PM
