Ground control Coilovers rates , need some input
Old Sep 9, 2007 | 07:25 PM
crxsiperf's Avatar
* B A N N E D *
Default Ground control Coilovers rates , need some input
What springs is everyone using and along with what struts is the best setup . 95 hatch with gsr swap . I have , from what i have researched :
front 200.64.58 = 330lbs
Rear 180.64.44 = 246 lbs
WIth agx struts , now even on the softest setting with 2 finger gap on the wheels , rides like total *** and pulling out is so jerky in this thing .
I bought these from ebay about 2 years ago and only have less than 500 miles probably on them . Are my rates right? Are my struts blown ?
Tell me something to make me feel better here lol
Old Sep 9, 2007 | 07:32 PM
BEE1's Avatar
Koni yellows would be best matched with ground controls.
Old Sep 9, 2007 | 07:35 PM
bmoua's Avatar
how old are your struts? were you running any other springs/coilovers before you ran the GC's?
Modified by bmoua at 8:50 PM 9/9/2007
Old Sep 9, 2007 | 09:19 PM
instrument's Avatar
your spring rates are VERY soft.
if you find this setup too bumpy, then you need to upgrade your struts.
and what do you mean pulling out is jerky?
sounds like you don't know how to use your clutch, unless you mean you're having a lot of wheel hop.
my spring rates are almost 3x yours, and i have no issues.
Old Sep 9, 2007 | 09:33 PM
Eran's Avatar
HT White Ops
Did you use the supplied urethane sleves and o-rings for the install? Did you cut your bumpstop per the instructions?
JaimmyACA
Suspension & Brakes
Feb 5, 2012 03:43 PM
92integraVTECgsr
Suspension & Brakes
Nov 22, 2005 10:44 PM
BrandonClaps
Nov 7, 2003 10:36 PM
Understeer
Jul 16, 2003 11:21 PM
fiebru1119
Apr 23, 2002 07:35 AM
