Weight reduction...
Old Sep 9, 2007 | 03:42 PM
1.8EG-T's Avatar
Default Weight reduction...
Does anyone have any ideas on weight reduction for an EG...already removed the sound deadening material...rear seats...air conditioner...this is not a daily driven car so please, don't be shy...
Old Sep 9, 2007 | 04:18 PM
DCSportEJ1Civic's Avatar
Default Re: Weight reduction... (1.8EG-T)
light weight? well for a lot of money, carbon fiber hood, trunk/tailgate, fenders, and doors. lol
Old Sep 9, 2007 | 04:19 PM
cartune network's Avatar
Default Re: Weight reduction... (DCSportEJ1Civic)
lexan windows.? get rid of the reinforcement in the doors. idunno that all i can think of but if u do that i hope u have a cage.
Old Sep 9, 2007 | 04:48 PM
nix94delsol's Avatar
Default Re: Weight reduction... (cartune network)
take a lug nut off every wheel
Old Sep 9, 2007 | 05:12 PM
kayelemenohpee's Avatar
get opn a diet and excersize, poop before too. put in smaller motor
Old Sep 9, 2007 | 06:12 PM
blk92_d16's Avatar
We need to know if this is a budget W.D. or like others mentioned, can you CF everything? Lexan?
Old Sep 9, 2007 | 06:15 PM
KillAHonDa's Avatar
power steering.....
Old Sep 9, 2007 | 06:26 PM
Murk 'EM's Avatar
Default Re: (KillAHonDa)
gut the dash its ****** heavy back there... get rid of the blower motor piping all the bs you can cut some of hte supports out back there.. hell make a new dash... its not dd so grab a couple pices of sheet metal weld them togeather in throw it in (using the same bolt holes as the stock dash)
Old Sep 9, 2007 | 06:32 PM
blue gd3's Avatar
Don't forget Hydrogen. Pump it in the tires to the maximum psi.
Old Sep 9, 2007 | 06:36 PM
mini-meEj1's Avatar
Default Re: (Automatic Blue)
alll interior panels
Old Sep 9, 2007 | 06:42 PM
Cruzan77's Avatar
Default Re: (mini-meEj1)
Might as well remove the gas tank...
Old Sep 9, 2007 | 06:49 PM
rmcdaniels's Avatar
Remove everything:
Old Sep 9, 2007 | 07:19 PM
HeikDiesel's Avatar
Default Re: Weight reduction... (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Remove everything:
wowza, whats this car used for?
Old Sep 9, 2007 | 07:29 PM
Murk 'EM's Avatar
Default Re: Weight reduction... (HeikDiesel)
it looks to me like he uses the car to pick up the kids from school......
hey if you take out the spare you drop a couple lbs ya know... take the seats out put 1 "sheet metal" seat in i dont know what there called its like the drag seats or something they weigh like 10lbs, is it a autoxcar or drag car? if its drag the pick up a fuel cell drop the big tank.. seriously take out all hte bs supports and bars and metal from the dash area.. take out the door supports (the bar thats in the door)
Old Sep 9, 2007 | 07:30 PM
rmcdaniels's Avatar
HPDE's and time trials, road course stuff, an occasional autocross. I still need to get the cage in it, and I pulled the motor to put some new pistons in it, so it's super lightweight right now.
Old Sep 9, 2007 | 07:35 PM
rmcdaniels's Avatar
Default Re: Weight reduction... (95_acc0rd)
Yeah, I take the spare out at the track, and I need to leave OEM seats in it until I get a cage, then I've got an old Kirkey aluminum drag seat that weighs less than 10 pounds that I'll put in it, although I need to leave a passenger seat in it for HPDE's so the instructor has some place to sit, although I may remove it for time trials.
Old Sep 9, 2007 | 07:57 PM
JDMBoostedDA's Avatar
for road racing you cannot remove the inner door support.
if your car is an SI, remove the sunroof. VIA a peice of rivetted lexan or just shaving it altogether.
Rear disk brakes will help you a lot, and im not sure if they weigh more or less.
Shave the spare tire well. I cut mine out of my Honda Challenge Integra im prepping for next year and welded in a peice of flat sheet metal, I then cut a rectangle out for a fuel cell that has an overhanging lip. I rivetted it into place and also put a support bar inderneath on 2 sides. Its still lighter than stock.
if you have money... Memory fab carbon buckets all the way.
Wheeeeeellllssssss. The best way to free up HP and lighten your car is by running the smallest lightest wheel possible for your brakes and still having adiquit(sp?) ventilation. Also just think, what ever weight you save per wheel is multiplied by 4 for your total weight savings.
Hope that helps. Any other questions PM me. If i think of anything else i'll post it.
Old Sep 9, 2007 | 08:02 PM
crazyguy's Avatar
ps pump...if u have any...spare tires and jack..audio system.head unit.speaker..carpet..door panel..carbon fiber hood..door..fender..and driver.
Dallasb84
Jan 26, 2015 09:04 PM
Jneri1987
Feb 14, 2013 10:30 PM
ndaworks
Feb 3, 2008 12:45 PM
SPOONfdEK
Jul 7, 2003 01:11 PM
