h22 swap injector question
i hate a 89 lude that i put a h22 in and am getting fire but i am not getting fuel will start with starting fluid
so can someone please tell what wrong istill have 4 wires on my dizzy that have no home can someone tell me where they go
the 2 wires that are by there self and 2 more from the big plug m thinking the cam sensor maybe
Dude, you gotta complete your sentences.. It's way to hard to try and understand what you're saying..
Tell us what engine you have, H22A, H22A1, H22A4, and what OBD you are using, OBD1 or OBD2. What Distributor are you using, OBD1 or OBD2?
What color are the wires? Can you take pictures?
ok in detail i have a 1989 honda prelude that had a b20a5. now it has an h22a4. i am running the engine with a po5 computer. i have a 1994 external coil distributor that came with an 8 wire plug and a 2 wire plug. i still have my igniter plugged in on the strut tower.the only time i get fire is when it is plugged in. i can't get my injectors to fire.
i found out that the 2 wire plug is igniter power 12volt and the tach.
the other eight are 2 for cylinder sensor
2 for the cam position sensor
2 for the top dead center sensor
1 for the igniter signal to go to pin A21
the last wire is a green wire which i cant find where it goes which is connected to igniter. so if some one could tell me where the solid green wire from the distributor ignition control modual goes to maybe that wll be my problem
also i was reading about taking out the igniter on the strut tower. which could also be my problem cause i didnt think i need 2 igniter units.
kmartcivic
Sep 2, 2008 10:50 AM
blaqman
Apr 1, 2007 10:28 AM
