Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Car won't start, already checked basics, HELP
Old Sep 9, 2007 | 03:11 PM
GI8U2racing's Avatar
Default Car won't start, already checked basics, HELP
I just finished up doing a cable to hydro tranny swap and some suspension upgrades. I drove the car about 2 months ago last, and have changed nothing on the engine. The battery is dead, but I am using a 2nd car to keep the battery up. When I hit the starter, the starter sounds like it's going good. I pulled 2 plugs, and I have spark about once a second. The plugs have a few drops of gas, and the top of the pistons look moist. I checked the grounds, fuel leaks, all the fuses, primed it 25 times, and the fuel pump is making noise (it's working). Since the battery was pretty much dead, is there any chance it lost the Crome tune? Compression is 112, 115, 115, 119 with the TB closed. I can go do another check at WOT, but they are consistent at least.
ANY IDEAS????????
Old Sep 9, 2007 | 04:40 PM
Default Re: Car won't start, already checked basics, HELP (GI8U2racing)
just replaced all the plugs, no difference
Old Sep 9, 2007 | 04:55 PM
rotten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing &raquo;</TD></TR><TR><TD CLASS="quote">I just finished up doing a cable to hydro tranny swap and some suspension upgrades. I drove the car about 2 months ago last, and have changed nothing on the engine. The battery is dead, but I am using a 2nd car to keep the battery up. When I hit the starter, the starter sounds like it's going good. I pulled 2 plugs, and I have spark about once a second. The plugs have a few drops of gas, and the top of the pistons look moist. I checked the grounds, fuel leaks, all the fuses, primed it 25 times, and the fuel pump is making noise (it's working). Since the battery was pretty much dead, is there any chance it lost the Crome tune? Compression is 112, 115, 115, 119 with the TB closed. I can go do another check at WOT, but they are consistent at least.
ANY IDEAS???????? </TD></TR></TABLE>
The crome tune is in EEPROM, so that shouldn't be a problem.
Sounds like it is just flooded.
Pull the plugs and the fuse to the ECU, crank it over a little bit. Pop the plugs back in, try to fire it up.
Old Sep 9, 2007 | 05:39 PM
Pulled the plugs and ECU fuse, turned it over for like 5 seconds, and blew compressed air in every cylinder. Every one smelled of gas, but no puddles or anything. After I got it all back together, still no start
Old Sep 10, 2007 | 08:05 PM
bump
Katie Vanaman
Honda Civic (2006 - 2015)
Apr 11, 2017 08:14 PM
JCritt
25
Apr 27, 2008 11:59 AM
GI8U2racing
Sep 19, 2007 09:56 AM
GI8U2racing
16
johnjohn410
Dec 17, 2002 10:21 PM
