DC JDM 4-1 header/OMNI test pipe bolts???
Old Sep 9, 2007 | 01:20 PM
B18C1NMotion's Avatar
Default DC JDM 4-1 header/OMNI test pipe bolts???
i'm running a dc jdm 4-1 header with a omnipower test pipe. the only bolts that fit through the holes on the collector flange were 13mm's. my question is, which nuts and washers do you use? obviously i'm using 13mm nuts and washers but the holes on the flange on the test pipe are HUGE and the nuts and bolts fall through and then come off. i've replaced them several times and its very annoying. any help would be much appreciated!
Old Sep 9, 2007 | 01:22 PM
Da9Gro's Avatar
Default Re: DC JDM 4-1 header/OMNI test pipe bolts??? (B18C1NMotion)
dude those bolts should have springs if they're missing you gotta get em thats probably why they slip thru
Old Sep 9, 2007 | 01:32 PM
Default Re: DC JDM 4-1 header/OMNI test pipe bolts??? (Da9Gro)
were they supposed to come with the header?? i keep hearing about people using springs with the bolts on these headers but i sure as hell don't have em...
Old Sep 9, 2007 | 04:32 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1NMotion &raquo;</TD></TR><TR><TD CLASS="quote">were they supposed to come with the header??</TD></TR></TABLE>
No, you reuse the stock springs. Just find washers that are large enough not to fit through the holes, and use multiple sizes if you absolutely have to.
Old Sep 10, 2007 | 08:06 PM
Default Re: DC JDM 4-1 header/OMNI test pipe bolts??? (Padawan)
i'll have to go and buy new oem springs because i'm pretty sure i don't have them anymore...unless they're still on the oem header.
Old Sep 11, 2007 | 02:05 PM
bump
Old Sep 13, 2007 | 05:29 PM
ttt
dinko
Jul 12, 2008 06:23 AM
Shaka01
Feb 28, 2006 02:58 PM
sshaikh01
Nov 8, 2003 11:15 AM
RISING SUN 1
Apr 28, 2003 10:14 PM
onyx00
Aug 10, 2001 07:05 AM
