CRX wont start
Old Sep 9, 2007 | 01:08 PM
curioso's Avatar
Default CRX wont start
ok here is my problem i have a 1988 crx with a jdm b16. i recently upgraded my fuel pump to a 255lb walboro and two weeks after that my car just died. i added gas and nothing no codes cranks and dies. i have spark.
Old Sep 9, 2007 | 01:26 PM
Crx dude's Avatar
Default Re: CRX wont start (curioso)
Did you test to see if you got power or signal to your fuel pump? maybe the main relay is done. I'm just curious to why you had to change your fuel pump?
Old Sep 9, 2007 | 01:29 PM
denraweb's Avatar
Default Re: CRX wont start (Crx dude)
Alternator/batter? You say it cranks and then dies...sounds like a power issue...You are getting gas to the rail right? And the fuel pump is priming prior to starting right?
Old Sep 9, 2007 | 01:34 PM
curioso's Avatar
yes pump works i hear it turn on car was running fine for 2 weeks and i checked relays and i am getting fuel to rail. i think its electrical thow. bettery is good just got it replaced.
Old Sep 11, 2007 | 05:58 PM
curioso's Avatar
TTT injecrotrs arent giving out enough fuel (and yes i changed them al ready)!! no codes and i ran out of stuff i think could be wrong
Old Sep 11, 2007 | 07:01 PM
Street Racer X's Avatar
Default Re: (curioso)
Maybe your ECU took a dump for whatever reason
Old Sep 19, 2007 | 05:06 PM
curioso's Avatar
i swapped ECU's same problem
solvent5
May 7, 2008 07:21 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
whitehf
Aug 6, 2006 01:22 PM
sm00thk0zz
Dec 13, 2004 08:53 AM
