Will Goo Gone hurt paintjob?
Old Sep 9, 2007 | 09:54 AM
Endemic's Avatar
Default Will Goo Gone hurt paintjob?
titles says all.. so discuss!
Old Sep 9, 2007 | 10:08 AM
Tad's Avatar
Tad
nope,
it's safe to use.
i've peeled plenty of stickers with it.
actually I prefer goof off, as it's a big stronger.
if you really go crazy w/ it, then you might want to polish the surface once
your done, but it's not that big of a deal.
Old Sep 9, 2007 | 10:14 AM
ecahatch's Avatar
Senor Miembro
Default Re: (Tad)
its safe, even on plastic like your window visors and such. theres a new goo-gone that smells like oranges. i suggest you use that.
Old Sep 9, 2007 | 10:24 AM
Endemic's Avatar
thanks for your answer! i proved to my mother of this page so i am right its safe to use. her bumper got chewing gum on it and i told her to use my goo gone works as well.. shes worried about paintjob so thanks.
Old Sep 9, 2007 | 10:27 AM
ecahatch's Avatar
Senor Miembro
Default Re: (Endemic)
yea i actually just got some gum off my fender/front bumper with it last week.
if you have a clay bar/spray that works too.
Old Sep 9, 2007 | 10:44 AM
Proto05's Avatar
Default Re: (ecahatch)
I just used goof off to remove the pinstripe adhesive, no harm done
Old Sep 9, 2007 | 10:48 AM
. a d a m's Avatar
Default Re: Will Goo Gone hurt paintjob? (Endemic)
You guys are ******* brave, goof off is some strong ****. I set a rag with some on there on a cd sitting on my desk by accident and realized what I did 5 minutes later, it had already eaten a hole straight through it.
Old Sep 9, 2007 | 11:44 AM
Proto05's Avatar
Default Re: Will Goo Gone hurt paintjob? (. a d a m)
Well as soon as I finished the area I washed it
Old Sep 9, 2007 | 11:53 AM
Chris.'s Avatar
Honda-Tech Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . a d a m &raquo;</TD></TR><TR><TD CLASS="quote">You guys are ******* brave, goof off is some strong ****. I set a rag with some on there on a cd sitting on my desk by accident and realized what I did 5 minutes later, it had already eaten a hole straight through it.</TD></TR></TABLE>
are you talking about this goo gone?
i dont see how that **** could eat through a rag, ive let it sit on my paint before for 10+ minutes and all it did was break up the glue.
to the op: its perfectly safe on paint, just make sure to get all of it off, then wash that spot off and then wax the area
Old Sep 9, 2007 | 11:54 AM
Jet.'s Avatar
Default Re: Will Goo Gone hurt paintjob? (4F CHR!S)
He is talking about "goof off."
Goo gone is pretty safe. I've used it on my car numerous times with no problem.
Old Sep 9, 2007 | 11:55 AM
Proto05's Avatar
Im talking about
Chris.'s Avatar
Default Re: Will Goo Gone hurt paintjob? (Jet.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet. &raquo;</TD></TR><TR><TD CLASS="quote">He is talking about "goof off."
Goo gone is pretty safe. I've used it on my car numerous times with no problem.</TD></TR></TABLE>
oh, guess i read right over that thinking he said goo gone
Old Sep 9, 2007 | 12:43 PM
Endemic's Avatar
i got that thingy off for my mother.. my mother's happy now. thank you
Old Sep 9, 2007 | 06:16 PM
A's 94 GSR's Avatar
BG-33P
goof off or goo gone didn't hurt my paint. I used both.
Old Nov 22, 2007 | 08:12 AM
inspireAZN's Avatar
Anyone have an idea of how to get these stickers off?
Old Nov 22, 2007 | 08:15 AM
BLANCOh22a4's Avatar
Default Re: (inspireAZN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspireAZN &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone have an idea of how to get these stickers off?</TD></TR></TABLE>
a good old fashion razor blade and goo gone or goof off to get the remaining residue left
Old Nov 22, 2007 | 08:16 AM
Morasso's Avatar
Razor blade.
Take one of those fat wide razor blades, and scrape them off... It won't cut your glass or anything so long as you dont GOUGE the blade into it. Super easy to do
Old Nov 22, 2007 | 08:17 AM
sohc95vtec-t's Avatar
use a razorblade just be real careful, and make sure your holding it flat against th glass and you wont have any problems
Old Nov 22, 2007 | 08:19 AM
SoullessJapaneseMachine's Avatar
Default Re: (Morasso)
pretty sure you can gouge too...glass is harder than steel
be careful if the stickers are inside though, cuz you'll razor off the defrost lines...ask me how i know
Old Nov 22, 2007 | 08:30 AM
super_mut's Avatar
I would buy a heat guy from harbor freight to heat the glue under the stickers up so that you dont accidentally scratch your windows with the razorblade.
Old Nov 22, 2007 | 08:37 AM
Baggy Spandex's Avatar
Default Re: (super_mut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_mut &raquo;</TD></TR><TR><TD CLASS="quote">I would buy a heat guy from harbor freight to heat the glue under the stickers up so that you dont accidentally scratch your windows with the razorblade. </TD></TR></TABLE>
They make razors that will never scratch glass. Tint shops use them
Old Nov 22, 2007 | 08:40 AM
get RIGHT's Avatar
Default Re: (Baggy Spandex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baggy Spandex &raquo;</TD></TR><TR><TD CLASS="quote">
They make razors that will never scratch glass. Tint shops use them </TD></TR></TABLE>
Yep, they make plastic blades if you are that concerned about it. I
have sold Hondas for 11 years and have used a razor blade to remove every window sticker in that time and I can vouch I have never seen a blade scratch the glass. Ever.
Old Nov 22, 2007 | 08:44 AM
Default Re: (get RIGHT)
yea same here, used razors alll the time to take stickers off glass.. you must be retarded if you scratch the glass if your holding the blade flat just hold it flat against the glass, dont push harder then you need to, real simple, but if your really concerned, then there are plastic razorblades like someone already said
Old Nov 22, 2007 | 05:19 PM
inspireAZN's Avatar
thanks guys! as you can see my friend and i tried peeling off some of the AEM part..jesus christ...i'll go try that now =D
Old Nov 22, 2007 | 05:57 PM
Leo C's Avatar
Night Owl
Instead of a razorblade use a hairdryer to get old stickers off. Much easier
