A/C blower only working when in the 4th (high) setting HELP!
Old Sep 9, 2007 | 08:04 AM
dkboyny11's Avatar
Default A/C blower only working when in the 4th (high) setting HELP!
Just purchased a DA for my girl. When I go to use the A/C I noticed that the blower seems to only work in the 4th setting. When in 1-2-or 3 it doesn't seem to blow anything. Any help is greatly appreciated.
Old Sep 9, 2007 | 08:21 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: A/C blower only working when in the 4th (high) setting HELP! (dkboyny11)
I think there is a resistor box for the slower speeds. That may be bad. It is part 7.
http://www.sonsacuraparts.com/...dIrno=
I you don't have a helm manual, you should download it for this issue. Search google for "hondahookup manuals".
Old Sep 9, 2007 | 08:40 AM
i-VTEC_do_you's Avatar
its almost a guaranty that its the blower motor resistor, it usually gets rusty from moister.
back prob the connector to find the + from the batt. (make sure the key is on), then test all other pins (should be 4 in total) to ground. if your test light does not light up then the resistor element is blown.
replace the resistor
Old Sep 9, 2007 | 11:12 AM
dkboyny11's Avatar
Default Re: A/C blower only working when in the 4th (Dogginator)
Ur the best! Thanks so much. I'm good with engines just had no clue about the blower motor.
Old Sep 9, 2007 | 11:13 AM
dkboyny11's Avatar
Default Re: A/C blower only working when in the 4th (i-VTEC_do_you)
Thanks
Danthemagicbum
Jul 20, 2011 07:45 AM
FD3S
Audio / Security / Video
May 22, 2005 02:34 PM
flex97itr
Nov 15, 2003 08:43 AM
VTECAcuraGSR
Apr 5, 2003 04:16 PM
