hasport dx to sir harness?
The only way to make it plug and play is if they also include a new ECU.
or a harness converter with new plugs.
The sensors in the distributor need to be rewired at the ECU because they go to different locations on the plugs.
If it is just a wiring harness, then you will need to do some modifications on your own. <U>I could be mistaken on this one</U>. I have done a whole bunch of DX to Si convertions and it really is not that hard.
Follow the DX to ZC convertion on Hybrid Honda.
I bought one from Hasport and it's not really plug and play...they will include a list of steps to follow like removing some of the pins in your ecu and replace the new connected wires from the harness. But it's relatively easy. *make sure that the core you're sending is in good quality or you'll end up replacing and rewiring some if not all the sensors. I sent a DX harness that I bought from a wrecking yard to avoid down time and when it came back, every time I had to plug a sensor in, the wires just breaks in half...bummer..
thanx, that is what i wanted to know. basicaly it is not worth the 250 they are charging. i can wire and i have time and all the info online.
I agree...it's a bit pricey, but I was too eager and impatient. I could have wired it all myself, saved me some bucks and probably had better quality wires. It all depends too if you have more time than money...not that I have more of either one. There were a few hang ups on my swap like, wrong intermediate shafts, waiting for parts, and since I was living in an apartment then, I had to wait the next day to sign authorization to leave items by my door or pick it up myself after 3 attempts in their warehouse (ups, fedex, post office)...So when it was time for the harness, I just called them and sent my core....F*&ck it, I already spent more than I should anyway, whats a few more bucks...You probably know, how it is...Good luck!
4gencivicef9
12
Jul 31, 2006 05:30 PM
ITR981002
Jan 27, 2004 07:48 AM
