88-89 hatch SiR cluster conversion harness with electronic VSS
This is an 88-89 civic hatch dash harness that's been converted to run an ef8/ef9 jdm SiR cluster.I didn't wire up the door ajar sensor, hatch open indicator, catylytic converter overheat, or low fuel light. I couldn't find that last plug I needed. Also you have to run wires for the speed sensor. There is a lead for it on the harness and its only 3 wires. I will label the wires on the harness for easy installation. I had this harness on my ef before and I had the speedometer working but I had to use the VSS plug on a diff car.Pretty easy to hookup. Here's what's included:
-88-89 dash harness already wired up with plugs
-electronic speed sensor(with plug) that has been modified to use on your stock motor
Its easy to wire up the cluster on your own but this is for people who don't want to bother or are uncomfortable hacking up the stock harness.
Pics up later
I'm aksing $70+shipping
Holla
DK
Modified by thevtecnician at 8:33 AM 9/9/2007
Pics up later
Holla
DK
