help? were can i get 96-97 ITR brake rotors 4x114
fastbrakes sells them, most people just redrill 4x100 teggy rotors. I bolted 5lug type r calipers and 96 prelude vtec rotors on the front of mine for bigger brakes, most people talk abot shiming and grinding but mine bolted right up
https://honda-tech.com/zerothread?id=2090223
a tech thread i made. alot of good info in here. be prepared to reading though.
easiest options are to get some 4x100 rotors from the gsr and have them redrilled to the 4x114.
option 2 is to get the jap spec rotors.
option 3 is to change your caliper to the 98+ accord, 93+ prelude vtec, or 98+ ITR and run the prelude vtec front rotor for a 11.1" brake upgrade. a good bit bigger and more stopping force than the 10.2. This is a bolt on affair and will require you to only grind the front upper part of the caliper slightly depending on which wheel you are running.
hope this is more helpful to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stunna BEN »</TD></TR><TR><TD CLASS="quote">
Any idea where you can order these new?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stunna BEN »</TD></TR><TR><TD CLASS="quote">what did you decide on bro?</TD></TR></TABLE>
well till i find out if i can get oem jdm spec rotors ill probably go with the prelude vtec rotors and calipers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAchiko »</TD></TR><TR><TD CLASS="quote">
well till i find out if i can get oem jdm spec rotors ill probably go with the prelude vtec rotors and calipers</TD></TR></TABLE>
I forget what site it was, might have been passwordjdm, but one of those JDM distributors started selling new ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLacK FirE »</TD></TR><TR><TD CLASS="quote">
I forget what site it was, might have been passwordjdm, but one of those JDM distributors started selling new ones.</TD></TR></TABLE>
well ill check let me know if u find them
DuongBros.
Suspension & Brakes
Oct 18, 2008 02:04 PM
