h22 intake manifold
The F22B1 Manifold/Plenum is 58mm and the H22 Throttle Body is 60mm. The bolt patern for the H22 TB and F22 Intake match but your not going to gain anything unless you get the 58mm F22 manifold ported to match the 60mm H22 TB.
As for the intake actually fitting. There are some modifications that would need to be done. The runners on the H22 are a larger in diameter than the intake ports on the F22 head. The water port coming from the head and going through the manifold doesn't match up. With some enginuity these problems could be overcome. Why not give it a try and tell us what you come up with.
Modified by GhostAccord at 5:36 AM 9/9/2007
no, I think you are thinking of the H23 IM. I don't think the H22 is the same.
if you want something larger and simpler, try the F23 IM.
http://www.accordinglydone.com...ld+IM
pictures dont work anymore but....
