i have a couple questions about my setup. CTR pistons in LS block
Old Sep 8, 2007 | 07:52 PM
dorko-t's Avatar
Default i have a couple questions about my setup. CTR pistons in LS block
i picked up a bone stock LS with 80k miles on it for 120$, and i decided to rebuild it..
here is what i chose.
the block:
-usdm b18b1 block (pressure tested, hot tanked)
-std bore 81mm CTR pistons and wrist pins
-stock LS rods
-micro-polished crank
-ACL bearings
-oem rings
(im debating arp vs. new OEM rod bolts?)
(should i knife edge the crank?)
the head:
-stock LS head, with stock internals
-it has been resurfaced/hot tanked/pressure tested
-arp headstuds
I was wondering since the dome on the CTR pistons, is pretty decent compared to the LS dome, but if i was to use a OEM 3-layer headgasket, would i have any problems with piston-head clearance? i know the safest clearance is around 35-40 thousands, but since im using stock LS rods, and crank the i figured the piston-deck height should be approx the same as the LS pistons. NOW if i knife edge the crank would this make a difference, in the pistons to deck height???
never built a motor before, im all new to it.. i've only done swaps and turbos...no internals.
i am scared to run aftermarket cams, b/c i dont want the valves to smack the pistons, and expletive everything up...i believe if i used a oem HG the CR would be close to 12.0-1?
i havent ever heard of anyone doing this before, so i figurd i'd ask HT and get some opinions/answers...
any help would be appreciated.!@!
Modified by dorko-t at 12:10 AM 9/9/2007
Old Sep 8, 2007 | 08:56 PM
HondaCivicSiR1's Avatar
Default Re: i have a couple questions about my setup. CTR pistons in LS block (dorko-t)
do you already have the ctr pistons?if not i would go with p30',pr3 or jdm itr pistons instead and use a 2 layer head gasket.you will be ok to use after market cams then along with springs and retainers.
Old Sep 8, 2007 | 09:51 PM
1 2 NV's Avatar
this **** has been covered 5000 times. god all motor forum sucks **** anymore.
Old Sep 8, 2007 | 10:43 PM
dorko-t's Avatar
Default Re: i have a couple questions about my setup. CTR pistons in LS block (1 2 NV)
yes i already have the ctr pistons, the only reason i got them was because the compression was the highest for OEM pistons.
and if it has been coverd 5000 times, can you please send me a link to one of the threads, i searched and only one thread came up, but it was a GSR with ctr pistons.
thank you
Old Sep 9, 2007 | 06:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">this **** has been covered 5000 times. god all motor forum sucks **** anymore.</TD></TR></TABLE>yea that was a very helpful post
Old Sep 9, 2007 | 08:28 AM
kartman5's Avatar
Default Re: i have a couple questions about my setup. CTR pistons in LS block (HondaCivicSiR1)
No quite sure, but I think you would of been better going with JDM ITR pistons
and building the head. My son did this with his LS set-up and it tuned out very
nice. Can you return the CTR pistons?
Old Sep 9, 2007 | 09:07 AM
dorko-t's Avatar
Default Re: i have a couple questions about my setup. CTR pistons in LS block (kartman5)
im not using jdm itr pistons, i am using ctr pistons...
and no i cannot return them, i can sell them but i dont want to, i already had jdm itr pistons and the dome wasnt big enough
any more suggestions?
Old Sep 9, 2007 | 10:03 AM
JDM JEFFREY's Avatar
have fun running race gas all the time
if you want a good street motor go with the p30s. pct(ctr) comp is way to high
SEARCH<U></U>
Old Sep 9, 2007 | 11:47 AM
dorko-t's Avatar
Default Re: i have a couple questions about my setup. CTR pistons in LS block (JDM JEFFREY)
ok you are answering all the wrong questions.
i want to know if im going to have enough clearance between the top of the piston, and the bottom of the head.?
if i have to ill run 2 HG's, or a thick cometic HG or something along those lines.
that will lower the CR, but it will be safe for my motor.
Old Sep 9, 2007 | 06:30 PM
you should be fine with an oem headgasket
cay the motor piston to valve clearance before you put the motor together.
Old Sep 9, 2007 | 08:18 PM
kartman5's Avatar
For a guy asking questions, you are really acting like a d---.
Old Sep 10, 2007 | 07:24 AM
Phil M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorko-t &raquo;</TD></TR><TR><TD CLASS="quote">
that will lower the CR, but it will be safe for my motor.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorko-t &raquo;</TD></TR><TR><TD CLASS="quote">im not using jdm itr pistons, i am using ctr pistons...
any more suggestions?</TD></TR></TABLE>
You are a moron.
SanadaSand207
May 23, 2018 02:59 PM
allmotorek8
Nov 5, 2007 06:14 AM
ekallstar21
Feb 5, 2005 01:08 PM
90teg
Dec 14, 2004 12:43 PM
