Tranny clunking sound questions
Old Sep 8, 2007 | 06:10 PM
JT's Avatar
JT
Default Tranny clunking sound questions
Has anyone experineced a slight clunking sound from the tranny when taking off from 1st gear, even at low speed? I can also hear it sometimes during quick deceleration and back on gas again. I tried to locate the sound by manually rotating the CV shafts and noticed there are some free play inside the tranny, and follow by a clunk sound If the shafts continue to rotate. It sounded like the gears are finally enaged. It sure sounded like the clunk noise that I heard but not sure...
The CV shafts are new and I didn't see any problem on the splines inside the tranny during the installation. The tranny has new Honda MTF and no other problems. I'm about to drop the tranny to install new clutch and flywheel. Is there anything I should check or adjust while I have the tranny out? How much free play is normal? Thanks in advance for any suggestions.
Old Sep 8, 2007 | 06:14 PM
mgags7's Avatar
What kind of free play are you talking about?
There are many things that could go wrong inside the trans that would cause a clunk like that. None of which you could check without disassembling the trans case.
Old Sep 8, 2007 | 06:23 PM
dagle's Avatar
Default Re: (mgags7)
i have this too.. i worried about it on the first day, but then i didnt see anything leaking and it engages fine.. i avoid 1st gear a lot and drive in 2nd gear just because 2nd gear doesnt get as loud and I drive in morning time. considerate of the light sleepers.
Old Sep 8, 2007 | 06:27 PM
mgags7's Avatar
lol light sleepers...
So you guys have a clunk loud enough to be audible over the engine?
Old Sep 8, 2007 | 06:34 PM
JT's Avatar
JT
Here is a video and sound clip of the free play and noise. Let me know what you think.
http://www.tsobad.com/jtso/Video/clunk.avi
Old Sep 8, 2007 | 06:40 PM
mgags7's Avatar
That is fine, thats just the diff having some room to move.
I don't think your gear clunk is related to that noise at all, from what I can tell that is completely normal.
Old Sep 8, 2007 | 06:54 PM
dagle's Avatar
no matt, i mean i dont like driving in first gear cuz it hits 4-5k rpm very fast and i have a no name header that likes to scream.
oh and mine doesnt sound like that, mine is a lot lighter and doesnt happen all the time.
if i really get on it, it doesnt make a sound.. if i drive slowly like parking gear then ya itll make a light clunk noise. someone told me it might be my clutch/pressure plate
Old Sep 8, 2007 | 09:27 PM
JT's Avatar
JT
It's good to hear that particular sound is normal. I just double checked the cv joints and they are fine. Oh well, I wonder what else could it be...
Old Sep 8, 2007 | 09:43 PM
ludemniac's Avatar
Default Re: (JT)
I have the same clunk in first gear sounds like theres some kind play inside tranny. I have same thing on two different preludes with mileage around 130k
Old Sep 9, 2007 | 07:26 AM
Giant_Bean's Avatar
Default Re: Tranny clunking sound questions (JT)
I have a clunk when i shift, usually in lower gears, but only then, not while in gear. Are your motor mounts good?
Old Sep 9, 2007 | 07:36 AM
JT's Avatar
JT
Default Re: Tranny clunking sound questions (Giant_Bean)
I don't have the sound while in other gears either, other than occasionally during quick deceleration and back on the gas again. It sounded like a worn out u-joint. Front and rear motor mounts are brand new. The driver side and tranny mounts are still good. It's more noticeable in a parking garage.
Old Nov 1, 2007 | 08:52 PM
HPI's Avatar
HPI
I have sound from my motor..It sounds like trans but,I can find the problem..I change the trans and still have noise
EF909
Mar 7, 2011 09:39 AM
Mike"IAMSLOW"Myers
Feb 24, 2008 02:40 PM
4drferio
Apr 29, 2004 10:59 AM
