What kind of valves should i use
Old Sep 8, 2007 | 05:18 PM
vttitan18's Avatar
Default What kind of valves should i use
I recently had my tensioner go out and some valves got bent in the process. Any suggestions on some very good after market valves to use with a 95 turbo charged h22a1 engine.
Old Sep 8, 2007 | 05:22 PM
mgags7's Avatar
ferrea is always a good choice, but there is no need to change from stock valves IMO unless you need a different size.
Old Sep 8, 2007 | 06:01 PM
117's Avatar
117
Like mgags7 said, nothing wrong with using OEM valves.
Old Sep 9, 2007 | 10:00 AM
Asian Invasion79's Avatar
Default Re: What kind of valves should i use (vttitan18)
I'm running ferrea valves on my H22. Comp plus series. I have my stock valve train sitting here if you want to buy it. its from JDM H22A. I have the stock jdm cams, valves, and valve springs. the engine only had about 30K on it when it was disassembled.
turboman2.2
Jul 4, 2010 10:08 AM
all-mtr-teg
11
May 27, 2008 11:40 AM
dand39
Feb 16, 2005 11:47 PM
BigPlansNoMoney
Nov 2, 2004 06:45 PM
LsBack
Sep 19, 2004 01:04 PM
