GSR cams
Old Sep 8, 2007 | 05:02 PM
egsr92's Avatar
Default GSR cams
What are the best cams for a b18c that is N/A now (and will be for a while) but will eventually go turbo, I am leaning either toward CTR cams, Skunk2 stage 1 or Skunk2 pro 1 cams (this having the highest lift/duration out of them). Thanks.
Old Sep 8, 2007 | 05:19 PM
rdeezy78's Avatar
Default Re: GSR cams (egsr92)
Ctr or Itr cams. If you get skunks don't get pro series if you plan on keeping those when you go FI. I'm not sure why, but when I asked which skunks to get I was told not to get the pro series. If you get skunks and want to keep them for good with n/a and use for FI get stage 2's and get ur ride tuned both now and for FI in the future. Good luck.
Old Sep 8, 2007 | 05:22 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: GSR cams (rdeezy78)
Skunk2 Stage 1's or CTR/ITR's.
Be sure to upgrade your valvesprings and retiners so you can take full advantage of those cams
Old Sep 8, 2007 | 06:50 PM
egsr92's Avatar
Hmm.. the new Pro1's from Skunk say ideal for racing turbo applications, the only thing I was concerned about with those is the degree of overlap, which cam companies rarely show.
Old Sep 8, 2007 | 08:16 PM
doood's Avatar
been there done that
Default Re: (egsr92)
pro1's are a good choice if you're looking to make big, big numbers. tony1 in the forced induction forum did a test with them and had impressive results. itr/ctr's will do just fine otherwise. lots of people making 500-600whp with those.
dc4teg95
Jan 24, 2007 02:36 PM
gsr x civic
Sep 29, 2006 01:47 PM
blakacintegera
Jul 21, 2003 12:52 AM
b18cInside
Dec 22, 2002 05:13 PM
far
Apr 4, 2002 09:52 AM
