Tranny gurus: Y1 LSD FD vs. S1 non-LSD FD, are they interchangable?
Old Sep 8, 2007 | 04:54 PM
Art701's Avatar
Default Tranny gurus: Y1 LSD FD vs. S1 non-LSD FD, are they interchangable?
I currently have both differentals out of the respective transmissions. I want to swap the 4.4 FD of the S1 onto the Y1 LSD. From searching H-T, I found that all "thin-spline" B-series cable trannies have interchangable parts. However, I also found that the Y1 LSD is the oddball, where the FD is not a gear that can be changed, but actually part of the casing. Can anyone verify this? I would take the differentials apart, but I don't have the necessary tools and shops are closed already. Thanks for any help.
Old Sep 8, 2007 | 11:36 PM
Art701's Avatar
Default Re: Tranny gurus: Y1 LSD FD vs. S1 non-LSD FD, are they interchangable? (Art701)
Nobody?
Modified by Art701 at 1:19 AM 9/9/2007
Old Sep 10, 2007 | 08:37 PM
Art701's Avatar
Old Sep 10, 2007 | 08:43 PM
thebigone05's Avatar
if it is a true y1 w/lsd then it should be a large spline input shaft, like the hydro trannys, atleast mine is.
The final drive ring gear is removable but will not mate with any other diff due to bolt count 15 for the y1 10 for everything else.
aaronhume
14
Apr 30, 2006 09:59 AM
red civic standard
Apr 11, 2002 09:02 AM
customx_
Dec 20, 2001 03:46 PM
