B-Series B18C5 ITR TB w/Boost Any HP Gains?
Old Sep 8, 2007 | 02:07 PM
spoonhatchblack's Avatar
Default B-Series B18C5 ITR TB w/Boost Any HP Gains?
Anyone w/actual experience has tried/used a OEM or OS (oversized) ITR Throttle Body on their Boosted Set-Up?
If so is there huge gains vs. stock TB's (B16,GSR's). Or are they Minimal Results and not worth it?
Dyno's Graphs would be nice as well.
***The reason for a(n) OEM ITR T.B.... its Factory (B-Series) & Perfect for Daily Driven & response and most importantly No sticky plate!***
Old Sep 8, 2007 | 09:30 PM
ej8's Avatar
ej8
Default Re: B-Series B18C5 ITR TB w/Boost Any HP Gains? (spoonhatchblack)
Get your stock TB bored by maxbore.com
Old Sep 8, 2007 | 09:41 PM
SwappedTURBOegg's Avatar
Default Re: B-Series B18C5 ITR TB w/Boost Any HP Gains? (ej8)
yeah anything but stock sucks for drivability
Old Sep 9, 2007 | 03:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8 &raquo;</TD></TR><TR><TD CLASS="quote">Get your stock TB bored by maxbore.com </TD></TR></TABLE>
Well this was going to be my 2nd option. Since i got a xtra GSR TB sitting here.
I just want to know more or less is if the OE TB will have improvements vs. Oversize?
Old Sep 9, 2007 | 05:04 PM
ej8's Avatar
ej8
Oversized will help out with any FI setup...the more power you make the more difference it will make. But you CAN go too big (a maxbore'd stock TB will not be too big for any setup) and loose your velocity when the airflow demands are not high enough for your setup.
I recommend using an aftermarket intake manifold. Be sure to match manifold design to what powerband you want.
B18PwdCivic
Nov 27, 2009 07:48 AM
86si
21
Jun 12, 2007 02:44 AM
Daniel-sanB1
Jun 7, 2007 02:23 PM
type B16
Aug 26, 2006 07:20 PM
WarrenB
Jan 23, 2004 12:58 PM
