start up problems need help
Old Sep 8, 2007 | 12:54 PM
ef9alldatime's Avatar
Default start up problems need help
i have a 91 civic i need help fixing my car. the car starts up but shuts off right away. i try to gas it and start the car at the same time but it still dies out right away.
Old Sep 8, 2007 | 07:30 PM
Default Re: start up problems need help (teflondon)
help me!
Old Sep 8, 2007 | 07:40 PM
maxx5905's Avatar
Any codes showing on the ECU
Old Sep 8, 2007 | 08:17 PM
Default Re: (maxx5905)
havent checked it thanx
Old Sep 9, 2007 | 12:37 PM
Default Re: (teflondon)
checked the ecu before the car starts theirs 1 blink and when the car is crank it blinks 2 times but after that nothing.
Old Sep 9, 2007 | 01:42 PM
maxx5905's Avatar
ok if thats one long blink and two short blinks thats code #12 that will be EGR Valve but i dont think thats whats the problem. Not sure where to begin. Timing, Vac. leak, Injectors, main relay??????
Old Sep 9, 2007 | 01:48 PM
denraweb's Avatar
Ok, I have to ask a common but obvious question...is there gas in the car? If there's very very little, like not enough to run the car, as soon as you start it, it will either die right away, or idle, and if you tap the gas pedal it falls on it's face...
Old Sep 10, 2007 | 09:19 AM
Default Re: (denraweb)
thiers plenty of gas. now i see 1 blink than 16 blinks on the ecu i probably didnt c it the irst time i looked.
Old Sep 10, 2007 | 01:35 PM
dr.carvorkian's Avatar
start with the obvious- check to ensure you have fuel to the injectors, then check to make sure your injectors are actually continuing to fire. sounds like a fuel-related problem to me- most times vac. leaks or ignition problems will not allow the car to start as yours does. so- supply, then delivery. report results.
Old Sep 10, 2007 | 04:23 PM
fireant's Avatar
Default Re: (dr.carvorkian)
If you need desperately to get it started, turn the ignition to the ON position and wait for 5 seconds, then the try to crank it.
Once my car was starting up and dying immediately too. I smelled fuel over where the injectors are, and found out that meant the injector o-rings were crusty and leaking. I replaced them and it worked.
(dont worry about replacing the expensive injector cushions, just do the little o-rings)
You might as well do the fuel filter too if you haven't yet, and clean the gunk off the injectors with some carb spray.
Old Sep 10, 2007 | 07:15 PM
maxx5905's Avatar
So is that one long blink and 16 short blinks?
Old Sep 10, 2007 | 07:39 PM
no just a blink, a pause and then 16 blinks thanx for your help guys
Old Sep 11, 2007 | 05:03 AM
fireant's Avatar
Code 16 is 'fuel injector problem'
I looked in the FAQs sticky on page one of the CRX/EF forum
https://honda-tech.com/zerothread/1508680
then followed the link about ECU codes to this:
https://honda-tech.com/zerothread?id=468260&page=3
Did you smell the fuel stink over your motor after you try to crank it?
Old Sep 12, 2007 | 04:56 PM
Default Re: (fireant)
no i did not smell fuel , but i found the problem it was the electrical part of the ignition switch
todubbled1
Mar 27, 2012 12:02 PM
peej
Jan 22, 2009 09:21 PM
dubzz24
Mar 2, 2007 09:14 AM
NoSwapNoCare
Mar 14, 2006 08:26 PM
oilguzzler
Dec 19, 2005 08:32 PM
