Mishimoto Radiator B.N
Selling a New Mishimoto Radiator application is for a Civic half size dual core, was planing to use but going a different route, some info on this rad.
Notes:
Core Size: 350mm x 358mm
Rows: 2
Inlet: 32mm
Outlet: 32mm
Core Thickness: 42mm
Tank Wall Thickness: 2mm
Fill Neck : 31mm
Note: This item is for Manual Transmission vehicles. For automatic applications, please purchase optional Mishimoto transmission cooler (P/N: MMTC-U)
Includes: Mishimoto Radiator, Mishimoto 1.1Bar Rad Cap
Model: MMRAD-CIV-92
MSRP: $250.00
Reduced Price Again$ 125 firm
thats $50 discount/off then what i payed
This is AS IS, no returns no refunds...
I was planing to use this for a b series motor
Benifits of using this radiator -other then whats listed on the notes.... A- it will give more space and give you that cleaner look since are engine bay or cluttered...B- if you plan to use long header or turbo setup..C- Cools alot better then oem rad., everything is strong and strudier inlcudin all metal down to the drain plug, Also for those who like Bling look just use some metal polish and it will Shine like no other
example:
Please bump if you look Thanks
Notes:
Rows: 2
Inlet: 32mm
Outlet: 32mm
Fill Neck : 31mm
Model: MMRAD-CIV-92
MSRP: $250.00
example:
