Stock GSR intake manifold or ?????
Old Sep 8, 2007 | 09:13 AM
pythoner's Avatar
Default Stock GSR intake manifold or ?????
Shold I get something like the Edlebrock preformer X of skunk2 intake manifold or should I stick with my stock GSR manifold?
also do the aftermarket manifolds have the secondarys?
thanks
stephen
Old Sep 8, 2007 | 09:36 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Stock GSR intake manifold or ????? (pythoner)
What's done to your motor ?
What do you want out of a manifold?
None of the aftermarket ones I know of have secondaries.
Old Sep 8, 2007 | 10:50 AM
pythoner's Avatar
it is in my daliy...and I am looking to build a decent all motor GSR over time and I am buying a hytech replica header and doing more work when I get the excuse to do it...
Old Sep 8, 2007 | 01:13 PM
b19coupe's Avatar
Where do you want your powerband?
Old Sep 8, 2007 | 01:20 PM
pythoner's Avatar
I have a CX motor right now.... any "powerband" would be nice...I would like some low but a good bit of mid and high...I drive like a dead person according to my freinds because I rarly see over 2500-3000 rpm's....but it (cx) does have to scoot some times
Old Sep 8, 2007 | 01:25 PM
b19coupe's Avatar
Default Re: (pythoner)
The stock GSR intake manifold will kick the crap out of any manifold below 4,500 RPM-if the butterflies are hooked up and working. Above, 6,200 or so, a Blox or Skunk 2 IM will be better.
Old Sep 8, 2007 | 05:48 PM
pythoner's Avatar
so I should wire up the butterflys and keep it stock...is that right?
Old Sep 8, 2007 | 06:45 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner &raquo;</TD></TR><TR><TD CLASS="quote">so I should wire up the butterflys and keep it stock...is that right?</TD></TR></TABLE>
If low end power means more to you then top end power, then yes. If you like to race or keep it wound up, then no.
Old Sep 8, 2007 | 06:59 PM
Rickdrizzle's Avatar
stock motor = stock manifold
semi built = aftermarket manifold
Old Sep 8, 2007 | 07:30 PM
HondaCivicSiR1's Avatar
Default Re: (Rick to the y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick to the y &raquo;</TD></TR><TR><TD CLASS="quote">stock motor = stock manifold
semi built = aftermarket manifold</TD></TR></TABLE>please explain why you say that?i have a aebs im on stock jdm gsr and a 64mm tb and i think it has a really good power band with those bolt on's.
Modified by HondaCivicSiR1 at 12:00 AM 9/9/2007
Old Sep 8, 2007 | 07:42 PM
Hybrid96EK's Avatar
Default Re: (HondaCivicSiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">please explain why you say that?i have a aebs im on stock jdm gsr and a 64mm tb and i think it has a really good power band with those bolts.</TD></TR></TABLE>
The bolts help out that much eh? Did you use some stainless steel ones or something?
Old Sep 8, 2007 | 08:00 PM
Default Re: (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">
The bolts help out that much eh? Did you use some stainless steel ones or something? </TD></TR></TABLE>yes i did
Old Sep 9, 2007 | 05:25 AM
OH_1fstgsr's Avatar
Take a look at this. Some information about a stock manifold.
https://honda-tech.com/zerothread?id=1820202
Old Sep 26, 2007 | 08:34 AM
SpoonC3's Avatar
I DONT NOE IF DIS WILL HELP YOU BUT I HAVE A SKUNK 2 MANIFOLD AND ITS GAY I HAVE RETAINERS VALVESPRING N VALVES N BORED MY BLOCK INTO 82MM SO IM IN ALL MOTOR BUT WEN I HAD THE STOCK GSR I PULLED FASTER DEN WEN I HAVE MY SKUNK2 MANIFOLD -- MY 1ST GEAR WITH THE STOCK MANIFOLD I TAKE OFF THE LINE FASTER BUT WITH THE SKUNK2 U HAVE TO WAIT UNTIL IT KICKS IN N I TAKE OFF THE LINE SLOWER .. SORRY IF DIS DIDNT HELP
Old Sep 26, 2007 | 08:46 AM
Hybrid96EK's Avatar
Default Re: Stock GSR intake manifold or ????? (SpoonC3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonC3 &raquo;</TD></TR><TR><TD CLASS="quote">I DONT NOE IF DIS WILL HELP YOU BUT I HAVE A SKUNK 2 MANIFOLD AND ITS GAY I HAVE RETAINERS VALVESPRING N VALVES N BORED MY BLOCK INTO 82MM SO IM IN ALL MOTOR BUT WEN I HAD THE STOCK GSR I PULLED FASTER DEN WEN I HAVE MY SKUNK2 MANIFOLD -- MY 1ST GEAR WITH THE STOCK MANIFOLD I TAKE OFF THE LINE FASTER BUT WITH THE SKUNK2 U HAVE TO WAIT UNTIL IT KICKS IN N I TAKE OFF THE LINE SLOWER .. SORRY IF DIS DIDNT HELP
English is the preffered language of this forum..
Old Sep 26, 2007 | 08:58 AM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonC3 &raquo;</TD></TR><TR><TD CLASS="quote"> DIS DIDNT HELP
there i was compelled to edit it and put the most informative part out and up front
Old Sep 26, 2007 | 10:22 AM
Top Ramen's Avatar
I have a couple of friends using GSR manifolds that I ported on motors making over 200hp at the wheels. They retain the butterflies for low-end performance since they are street cars.
Old Sep 26, 2007 | 03:22 PM
sounds good.
Old Sep 29, 2007 | 07:27 AM
SpoonC3's Avatar
Default Re: Stock GSR intake manifold or ????? (Hybrid96EK)
wow i guess i have to SPELL everything right ..... its a bay area thang yadadamean
NOCOASTcoupe247
May 20, 2013 10:17 PM
BLKTeg94
Apr 1, 2006 08:11 PM
Shizznaz
Feb 15, 2005 07:50 PM
danteisme
Feb 26, 2004 04:28 PM
