no brakes. Ahhhhh!!!!
Old Sep 8, 2007 | 08:15 AM
I Love My 4 door's Avatar
Default no brakes. Ahhhhh!!!!
Today while i was driving my brakes went on me. No warning or anything like that. There is no griding noise or leaks anywhere. My brake fluid s at perfect level and I never have had to fill it in the 2 years I have owned the car. I press my brake pedal all the way, and nothing. Scary. Lucky for me it was late and there wasn't a lot of people on the road when I went rite through a red light. So i throw the car in neutral and pull the ebrake to a stop. Eventually I got it home by the backroads. Any advice on what this can be ???
Old Sep 8, 2007 | 08:44 AM
SFlCrx's Avatar
did you do any work to the car lately brake related?
Old Sep 8, 2007 | 08:47 AM
Default Re: (SFlCrx)
nope. jus a cold air intake
Old Sep 8, 2007 | 08:50 AM
SFlCrx's Avatar
it sounds like you have some air in the system but it would not just go out on you like that while driving
Old Sep 8, 2007 | 08:57 AM
i know its wierd. do i fix that by bleeding the brakes ???
Old Sep 8, 2007 | 09:39 AM
adeline's Avatar
Default Re: (I Love My 4 door)
yes, did the pedal feel little at any point, not as hard to push before they went out
Old Sep 8, 2007 | 09:44 AM
Super Chicken's Avatar
Default Re: no brakes. Ahhhhh!!!! (I Love My 4 door)
It sounds to me like the master cylinder has failed. If you have no fluid loss and the pedal goes to the floor then the most likely problem is the M/C. Nothing else will cause the "bypass" symptoms you describe
Old Sep 8, 2007 | 09:48 AM
Default Re: no brakes. Ahhhhh!!!! (Super Chicken)
Yeah it was very easy to push in. And how much do master cylinders go for ?
Old Sep 8, 2007 | 10:26 AM
barely4dr's Avatar
you should be able to find one in the jy for ~$40
Old Sep 9, 2007 | 02:07 PM
goofball123321's Avatar
that crappened to me once, was pretty scary but I was in traffic going slow. I was still able to pump them a bit and they worked after. I bled my brakes after that, but it stll went to the floor slowly when hot. then I eventually changed the mc and that solved everything.
Old Sep 9, 2007 | 03:15 PM
Lo-Buck EF's Avatar
Default Re: no brakes. Ahhhhh!!!! (barely4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by barely4dr &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to find one in the jy for ~$40</TD></TR></TABLE>
thats not an item you want to buy used. get yourself a new one form autozone or advanced autoparts.
Old Sep 9, 2007 | 04:02 PM
Wes V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken &raquo;</TD></TR><TR><TD CLASS="quote">It sounds to me like the master cylinder has failed. If you have no fluid loss and the pedal goes to the floor then the most likely problem is the M/C. Nothing else will cause the "bypass" symptoms you describe</TD></TR></TABLE>
I second exactly what he said!
Wes
IGOTK22
Suspension & Brakes
52
May 28, 2021 05:48 AM
kornkid21792
Jan 9, 2018 09:54 PM
micah_m
Suspension & Brakes
Oct 13, 2014 09:11 PM
meanshyguy
May 18, 2009 11:04 AM
jwrape
May 25, 2008 01:33 PM
